c3002 locked up
  • dikman
    • Feb 2020
    • 16
    #31
    Re: c3002 locked up
    No worries mate, I think most of us are guilty of misreading a post sometimes when answering it. I haven't looked at it again yet, the office is only open 9-12 and I spent 2 hours today figuring how to get this bloody Canon apart. Easy once you know how, of course. Problem was two screws were stripped out of their plastic posts. It has a springloaded latch that has to be pushed in before closing the paper feed thingy, "someone" didn't know this and used brute force to try and close it!
    • fshead
      • 2376
      #32
      Re: c3002 locked up
      donated machine so why not just show them how to scan to USB drive and move on?
      • dikman
        • Feb 2020
        • 16
        #33
        Re: c3002 locked up
        Could do, I suppose, but I'm trying to keep things simple for them. I repaired the broken Canon and the Ricoh is now functioning with all previous facilities, including the user locks they had before, except for the scan-to-email. It's annoying me, but I think I'll quit while I'm ahead.
        Slimslob, one final word, when I try to enable SSL under WIM it states that "SSL is unavailable without a device certificate installed", and my attempts to create one result in the error 404, which you've explained to me. I see no obvious way of setting it to https. No matter.
        Again, many thanks for all the assistance members have shown. Now back to my retirement.
          • 37556
          #34
          Re: c3002 locked up
          The C3002 lacks the processing power to allow more than one function to have access to secure communications using SSL. When you have an application that requires a Device Certificate, it takes priority over scan to email over SSL. Unless they are using an application that needs a secure connection to another computer or server on the network, get rid of the Device Certificate. There is also the option to setup a local email relay service such as Stunnel on one of their computers.
          • dikman
            • Feb 2020
            • 16
            #35
            Re: c3002 locked up
            Thanks mate, I've convinced them to do without it, as it was really a convenience rather than a necessity.
            As for the processing power (or lack thereof) that makes sense as I noticed that it could be very slow responding when I made changes as Admin.
            Now I just have to fix my Lexmark laser, but that's another story.
            • fshead
              • 2376
              #36
              Re: c3002 locked up
              you can use a program like scan to pdf with the twain driver and then enable it to scan email addresses..
              Not much to it and it works
