MP 305spf squeaking in the fuser.
  • RMC8112
    • Nov 2019
    • 38
    [Misc] MP 305spf squeaking in the fuser.
    I have a MP 305 that is squeaking in the fuser. I have replaced the fuser twice within 2k copies, and its squeaking again. has anyone have this issue? Is there anything way to fix it without replacing the fuser?
    • 37048
    Re: MP 305spf squeaking in the fuser.
    Are you sure it is in the fusing unit? I have had new PCU with the cleaning squeaking against the drum.
    • RMC8112
      • Nov 2019
      • 38
      Yup I'm sure.
        Originally posted by RMC8112
        Yup I'm sure.
        try the fuser(s) in another machine to make sure.
        odds that 2 new fusers have the same problem.
        • RMC8112
          • Nov 2019
          • 38
          I would but unfortunately there is only one machine inectge office.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Are you using new oem fusers not refurbished if they are new the problem isn't the fuser.
            Regards Mark
            • Coptech
              worker drone
              • 460
              usually just the claws squeaking. put a touch of silicon oil on the tips and it rarely comes back. Not so much oil that it goes on copies. Just enough to stop the squeak.
              • Zeldaman
                • Mar 2011
                • 946
                Hi there!
                The only series squeaking with the fingers was KIR. Never had this issue with the GRIFFINS. Is there genuine toner in the machine????
                Greetings...
                • Coptech
                  worker drone
                  • 460
                  Originally posted by Zeldaman
                  Hi there!
                  Greetings...
                  Not used to the series names but the model that has been the claw squeaker in my experience is the little black and white 305+.If the thread was about the little color C305, I apologize.
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Series names is very common with trained ricoh engineers
                    Regards Mark
                    • Coptech
                      worker drone
                      • 460
                      Not so much in the states...Use the series numbers more than series names.
                      • anothertech
                        • 1757
                        Very true, not too common in the US, it always just makes it very confusing when people start talking names of machines.
                          • 37048
                          Coptech;1354942 Not so much in the states...Use the series numbers more than series names.
                          anothertech;1355352 Very true, not too common in the US, it always just makes it very confusing when people start talking names of machines.
                          Originally they were mostly used by Ricoh direct operations. They started out as design engineering project code names and were supposed to be corporate confidential. Engineering code names are the use of "The Manhattan Project" to refer to the development of the atomic bomb.
