Ricoh MP C2800 firmware
  • bbrain
    • Mar 2020
    • 17
    Hi,
    I am looking for firmware for Ricoh C2800.
    The current FW versions are:
    Module Name Version Part Number
    System/Copy 1.23 D0255562T
    Network Support 8.27 D0255563F
    Font EXP 1.03 D0255588
    OptionPCLFont 1.02 D0255589
    animation 1.3.1 D0255568A
    Printer 1.22 D0255572F
    RPCS 3.7.5.4.1 D0255574A
    Option PCL 1.02 D0255580C
    Scanner 01.22 D0255570G
    Network DocBox 1.03 D0255567E
    Web Support 1.10 D0255565F
    Web Uapl 1.08 D0255566D
    PowerSaving Sys F.13 D0255560F
    Engine 1.54:09 D0255117H
    OpePanel 1.09 D0251492D
    LANG0 1.07 D0251496B
    LANG1 1.07 D0251496B
    ADF 03.420:02 D3665604
    Thanks is advance!
    • 37533
    Re: Ricoh MP C2800 firmware
    Why don't you post what the problem is that you are trying to correct instead of asking for firmware that you might not need.
    • bbrain
      • Mar 2020
      • 17
      The problem is to scan to gmail.
      Tried all the settings, but no luck.
      SMTP set up correctly. The account is used by a hb C35 without a problem.
        • 37533
        MP C2800 is too old to support TLS which is required now by most email providers. It has to do with on board electronics and there is no way to correct with firmware.
        Your only option is to use aspmx.l.google.com as the SMTP server. You will be limited sending messages to only Gmail or G Suite users. You may have to configure the authentication email address to allow "Less Secure Apps".
        Send email from a printer, scanner, or app - G Suite Admin Help
        • sandmanmac
          • 3981
          Agreed. Firmware will solve nothing. You'll have to use another unencrypted solution.
          There are many workarounds
          • bbrain
            • Mar 2020
            • 17
            Thanks, will check the workarounds.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Correct
              Regards Mark
              • copier tech
                • 8174
                Hi,
                Thanks is advance!
                SSL not supported no FW fix so on my old boxes like this I set up a a SMB folder on a PC & users share this they can then attach & email as required.
                  • 37533
                  Thee is also software options such as stunnel.
                  • copier tech
                    • 8174
                    Not worth the effort for his old 2800!
                    • anothertech
                      • 1771
                      I'm not so sure, if it's in good condition keep it, MPC2800 was one of the best Ricoh machines ever made. I still have a few out going strong, I hardly ever see them.
                      • bbrain
                        • Mar 2020
                        • 17
                        It is in good shape, with 160k pages only.
                        • skinnyb
                          • Jul 2008
                          • 291
                          Hardware is robust. Software is terribly behind the times. Unfortunately not much can be done except use work arounds for scanning.
                          Sent from my LM-V405 using Tapatalk
                          • fshead
                            • 2376
                            i always described them as BULLET PROOF and do still have many along with the mpc3001/mpc3501 series too.
                            I just gutted one for parts as i decided not o resell them anymore as the mpc3503s are very good too that I now buy/sell.
                            WHY is scan to email so important?
                              • 37533
                              A lot of sales people will push it as a necessary feature. I had customers who could care less. They would rather scan to folder, then attach that pdf to an email that they composed to include text documents, spread sheets,databases, etc without having to print them first.
