240 w error 300-1
  • Rick
    • Mar 2007
    • 277
    240 w error 300-1
    I cant seem to find the solution to this error. I removed the transfer chrg assy. to eliminate it . I also unplugged the high voltage transformer board to eliminate it and still getting this error . The machine warms up but as soon as it trys to cycle it displays this error code. I know that it has something to do with charging but if I eliminate the chargers shouldnt it still cycle?Any Ideas anyone.
  • Rorschach
    • Nov 2008
    • 64
    Check the toner door switch as well. I've run into the same problem before, and it was caused by a faulty switch.
    The only other things I can come up with off the top of my head are the CGB power pack or the corona assembly, but you've already checked those. I'd go with the switch to start.
    Good luck!
    Today's subliminal quote is:
    • schooltech
      School District Tech
      • Jun 2008
      • 504
      I think that the 300-xxx error is for charge, and 400-xxx is for transfer.
      The charge assemblies can get flaky in these wide format machines.
      Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        Replace the charge and grid wires. I've had several of these throw the code before the PM cycle. Usually they are in small rooms. Also clean the housing of ozone. I've also had 2 that needed the entire housing.
