sc442/sc370-02 MPC4503
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Hey all...
    I'm about ready to incinerate this machine and cut my losses.
    Typical issue where the customer decided that the flag on top of the waste toner bottle looked unsightly and binned it before fitting the new bottle.
    Waste auger backed up...pcdu all backed up....itb had ridden off to the rear etc etc.
    Replaced the waste auger assy,new bottle and pcdu,ITB assy,PTR assy.
    It started throwing the SC442 right from the start.
    Swapped in a used ITB assy and started throwing SC370-02.
    Removed the density sensor shutter(Slim's idea from a previous post) and now we're back to SC442.
    I've searched the forums and found threads very similar to mine but the O.P usually just says " it was a blocked PCDU".
    Well...I have half a dozen off contract 4503 and have been swapping bit in and out with no joy.
    Even got desperate and fitted a drive assy...so you KNOW how desperate things are.
    I've tried new IPU,IOB,power supply...lift motor...lift sensor you name it.
    Any ideas?
  • anothertech
    • 1771
    Re: sc442/sc370-02 MPC4503
    I pulled these Ideas from another post...
    the Magenta toner motor also acts as the ITB lift motor. see page 7-95 of the Detailed Description.
    part # D1493280
    see video nugget Answer ID 258298
    my machine had the toner bottle cover misaligned such that the left locating pin of ITB was flush with ITB and not sticking out slightly(RH pin) was good
    but I also had to replace the coupling the goes thru the frame (couples to M toner motor to provide lift)
    Also, if I ran sp5804-150 ITB lift motor, the motor would grind and stall
    After realigning toner bottle cover, it was still slightly grinding.
    after replacing the coupling, the stalling and grinding was gone. I could even put my finger on ITB cam(front) and motor would slow down, but not stall(grind)
    parts for coupling:D1496310
    D1496312
    D1496309
    AW020224
    D1496311
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Thanks man...
      I checked the two locating pins but they look fine to me...not obstructed by the front toner cover and I've cheated the door and the belt turns freely.
      The fault is not so much grinding but that you can hear the lift motor cycle 4 times and then it throws the sc442.
        • 37652
        That sounds to me like the sensor that detects that the lift position or its associated wiring is defective.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          I've swapped that AND the harness Slim.
            • 37652
            Harness on the main frame, or only the ITB assembly?
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              The mainframe...running from the sensor to the IOB.
              • fshead
                • 2378
                For me I would GUT this machine and swap out a equal used one..
                I have stopped looking to solve every "riddle" with service codes and such and if it
                gets to this point i would cut my losses..
                If customer caused this then let them cover the cost...
                Just mark any parts you remove so if 2 yrs down the road you
                know where such parts came from..
                • GVeliz
                  • Apr 2020
                  • 2
                  Hey all...
                  Any ideas?
                    • 37652
                    So that would mean the IOB might need to be replaced. Then maybe the controller. Maybe fshead suggestion might end up costing you a lot less.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Hey all...
                      Any ideas?
                      Sc442 we had some of the brackets that holds the lift gear on rear frame bend have a look
                      Regards Mark
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        Thanks for the suggestions guys.
                        Somebody mentioned the toner bottle cover being misaligned and causing an issue with the seating of the ITB.
                        I checked that cover and it's certainly not sitting right...even though the locating pins for ITB look ok.
                        The front door switch is being a dick and it's for sure the fact that the cover isn't quite right.
                        I'll have at it today and let you know what I find.
                        UPDATE:
                        It was in fact the front toner cover cover not being seated correctly over the shoulder of the locating shaft for the ITB assy.
                        A trap for young players and tired old techs like me..!!!
                        Thanks for the help.
                        • copier tech
                          • 8236
                          Thanks man...
                          Have you run an input check on this sensor?
                          • davel
                            • Oct 2011
                            • 1109
                            Problem has already been resolved, 11 hours ago.
                            • copier tech
                              • 8236
                              What was the solution should anyone else reading this post have this issue?
