mp6001 SC142 urgent
  • hsh6049
    • Jul 2012
    • 64
    [Error Code] mp6001 SC142 urgent
    hi all
    i have problem with ricoh mp6001 sc142 after using ADF copy about 1500 pages books..... after finish around 30 minutes into sleep mode than wake up again
    first appear sc101 than sc142
    enter sp mode 7807 clear code than
    1: cleaned all optic section and mirror + lens +lamp is on
    2- cleaned white plate
    3- checked all connector and harness
    but still give me these code any one can help me
    note : When switch on machine the scanner move to below the white plate than lamp turn on but it wont move back to original position after 1 or 2 seconds (normarlly about 1 or 2 seconds will move back to original position)
  • copier tech
    • 8131
    Re: mp6001 SC142 urgent
    Originally posted by hsh6049
    hi all
    Switch the machine off for around 30-60 mins then turn back on the can overheat. (that's my theory)
    • 8T2
      • Aug 2015
      • 257
      Home position error is sometimes caused by too long screws on slit glass cover. I've been home too long and can't remember what the cover looks like on those or if this is a possible fix so apologies if I'm talking irrelevant nonsense lol
      Sent from my WAS-LX1 using Tapatalk
      • Mark Bbb
        • Jun 2012
        • 1662
        When this would be the case, than that would be noticeable when moving the scanner manualy.
        Do you notice some friction or blocking when moving the scanner from right to left?
        • Mark Bbb
          • Jun 2012
          • 1662
          • Zeldaman
            • Mar 2011
            • 946
            Hi there!
            Had this problem once, reason was the SIOB-board pn D0625180.
            Greetings...
            • NeoMatrix
              Senior Tech.
              • 3513
              There's a lot of old threads relating to MP6000-1 series DF.
              In any web browser type "search site:copytechnet.com MP6001 DF" no quotes.
              HTH
              • fshead
                • 2366
                I would at least pull the radf and shake all the staples,paper clips out and the reseat all brd connectors and blow unit out with air.
                It might or might not work but at least you took that out of the equation.
                  • 37382
                  Unless you are also getting SC121 it has nothing to do with the home position sensor.
                  Most likely the exposure lamp it self or the lamp regulator board/scanner IO board.
                  • hsh6049
                    • Jul 2012
                    • 64
                    thanks for your reply.....switch on this morning it back to normal but after copy around ten copies sc142 again .....
                    • hsh6049
                      • Jul 2012
                      • 64
                      thanks for u reply....try to move this morning smooth
                      • hsh6049
                        • Jul 2012
                        • 64
                        thanks a lot ...and could be exposure lamp overheat or not????????? use adf to copy 2books around 500++pages both sided ..is quite hard to get the scanner IO BOARD ..possibility lamp regulator board?
                        • GIUBOSS
                          • 1392
                          clean and lubricate the scanner guides and check if the engine overheats
                          • farhad
                            • Apr 2020
                            • 40
                            hi
                            i have this problem 1 years ago
                            test you SIC cabls in you ADF
