Error code E-1 Ricoh
+ More Options
Posts
  • jctoy
    What would the error code E-1 refer to on a ricoh ft 4522. As well to what part's might be needed for repairs....
    Thanks JC
  • sandmanmac
    • 3990
    Should be a 3 digit code. press the "." key to display the last 2 numbers. However all "1xx" codes are related to scanner: Either the Lamp is blown, but more often it is a home position sensor out of position, or lens stuck (often after cover has been removed for optics cleaning etc.
    • mujibur
      • 53
      Thanks JC
      you chek expose lamp
      a/c drive board defictive
      • mujibur
        • 53
        codes (E1 to E7) are displayed in the copy counter. To display
        both digits of the E-code, press the Enter key.
        Example:
        When the machine detects the E11 condition, E1 is displayed in
        the copy counter. Hold down the Enter key, and "11" is displayed
        b) When service call (E5) conditions occur, they cannot be cleared
        by turning off/on the main switch, for safety reasons. The following
        procedure must be performed to clear these service call
        conditions:
        1. Turn on the main switch.
        2. Turn DIP switch 101-1 on and off.
        3. Turn the main switch off and on.
        • jctoy
          Thanks for the help,
          My cleint plans to dump it, as he should. Time to sell him a new one.
          Thanks Agian, JC
