[SP 4510] Drum Unit
  • fvargasbarrote
    • Jun 2020
    • 4
    [SP 4510] Drum Unit
    Good afternoon.
    Perhaps you are tired of hearing about the problems with the SP 4510 drum units and the risks that appear on them, we are using a Katun toner and they do not last long, 2k, 3k maximum. Up-to-date printers with the filter, will only the original toner work on them?
    • 37529
    Re: [SP 4510] Drum Unit
    Originally posted by fvargasbarrote
    Good afternoon.
    You do not need to post the same thing in both the Ricoh copier forum and the Ricoh printer forum.
    • sandmanmac
      • 3981
      Good afternoon.
      So, you've come here solely to inform us that crappy, low grade toner is not a good idea?
      That's just an amazing bit of insight. Who Knew???
      Thank you so much!
      • Zeldaman
        • Mar 2011
        • 946
        • copier tech
          • 8169
          Good afternoon.
          I have been beating this same drum since the 80's compatible toner WILL RUIN YOUR MACHINE!
