Mp2852 firmware update problem
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    Hi friends Mp2852 while updating firmware by using sd card take long time and still not finish hang on engine update so what is the problem and how to solve the problem please help me friends...
  • davel
    • Oct 2011
    • 1107
    Re: Mp2852 firmware update problem
    Corrupt firmware file, did you get it from Ricoh.
    • kanagavel
      Service Engineer
      • Feb 2020
      • 78
      Yes, i get it from ricoh, now machine showing E32
      • kanagavel
        Service Engineer
        • Feb 2020
        • 78
        How to solve the problem please help me friends
        • sandmanmac
          • 3981
          When the error screen is displayed:
          clear modes / 1 4 3 / clear stop (x3) / reboot
          Then try again
          ALSO, is there a specific reason you are trying to update F/W?
          • Juggy
            Technical Support
            • Sep 2007
            • 101
            Adding to sandmanmac comments.
            After clearing . Reformat the SD card and load the firmware again and continue updation.
            • kanagavel
              Service Engineer
              • Feb 2020
              • 78
              Thank you for the reply sir and I will try this
              • kanagavel
                Service Engineer
                • Feb 2020
                • 78
                Then try again
                Yes machine always showing sc899 that is why i try to update firmware machine current NIB version is 10.68 so I try to update it to 10.70
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  romdata - package?
                  • copier tech
                    • 8172
                    If you are updating using package try just the engine fw in the romdata folder.
                    And leave the LAN disconnected until the update has completed.
                    • kanagavel
                      Service Engineer
                      • Feb 2020
                      • 78
                      • mrwho
                        Major Asshole!
                        • 4299
                        Also, when you update one firmware, it's advisable to update all the others to the latest version.
                        I've had problems (not that one, though) when just updating network and not the others.
                        Mascan42
                        Ibid
                        • FrohnB
                          • Jul 2017
                          • 1919
                          They have a specific "Custom Firmware" for SC899 issue released 5/27/2014.
                          D120-D121-D122_PCL_LR0005_v1.03.1_SDcard
                          When printing a certain website by using a PCL5 or PCL6 driver, an SC899 error occurs. Cause: The character-rendering position is incorrectly calculated during the font-hinting process, which causes memory corruption and results in the SC899 error.
                          Make sure you load that version of the PCL firmware.
                          Still do the update for the others too, because the 12.70 NCS firmware was required for newly added SMBv2/v3 support. (Also requires you to update System, Scanner, web support).
                          Make sure they have the correct drivers loaded too. NO PCL6 V4, No Universal.
                          Strictly PCL6!
                          Omertà
                          • mrwho
                            Major Asshole!
                            • 4299
                            Strictly PCL6!
                            I'm a fan of pcl5 myself, and use it whenever I can...
                            Mascan42
                            Ibid
                              • 37532
                              You must have a lot of customers currently having trouble printing. Windows Update Has blocked print cabability!
