Mp2852 firmware update problem
    • 8146
    #16
    Re: Mp2852 firmware update problem
    Is a resolution to this issue, where a tech has to go onsite to fix the problem, considered billable labour, even when there is a toner/ labour/ parts service contract in place?
    • FrohnB
      • Jul 2017
      • 1919
      #17
      No. Since it's an issue (firmware) with our machine, it wouldn't be billable.
      If it was an issue with the customer's network or computer, then that would be billable. Say, the customer's IT department neglected to load the proper drivers for a device (even though our company usually does this upon initial setup at customer location), or did an update to the server/ network that caused a print issue, or changed a password and scanning stopped working.
      Omertà
      • Notrons
        • Apr 2016
        • 71
        #18
        I had this same problem a few years ago. Some how, the file you are updated was corrupted during the upload process. Both old and new firmwares are corrupted and the only way to fix it, is to replace the controller board. I have had this happen to me twice on two different modals, using SD card to update. I try not to use that method and if I have time, I update thru WIM or ARMS if that machine is on @remote.
        • anothertech
          • 1762
          #19
          Originally posted by mrwho
          Also, when you update one firmware, it's advisable to update all the others to the latest version.
          I've had problems (not that one, though) when just updating network and not the others.
          I wish you would tell my coworkers that, they just was to update whatever is causing them a problem today, not worrying about tomorrow.
          I think it's better to be proactive with firmware but most techs disagree with me and tend to be reactive.
          • mrwho
            Major Asshole!
            • 4299
            #20
            You must have a lot of customers currently having trouble printing. Windows Update Has blocked print cabability!
            Had my first one right after making that reply. Ain't karma a bitch?
            Mascan42
            Ibid
              • 37379
              #21
              Thanks for the chuckle.
              • kanagavel
                Service Engineer
                • Feb 2020
                • 78
                #22
                Originally posted by sandmanmac
                When the error screen is displayed:
                clear modes / 1 4 3 / clear stop (x3) / reboot
                Then try again
                ALSO, is there a specific reason you are trying to update F/W?
                Hi sir i try your idea but not working sir i press clear mode and 143 and stop key 3 times nothing showing
                  • 37379
                  #23
                  Did you then immediately reboot?
                  • FrohnB
                    • Jul 2017
                    • 1919
                    #24
                    Had to use that sequence on a 3504ex last week.
                    You Type in the code, and then you should hear a beep after the sequence. Then you reboot machine.
                    Ours was caused by ARFU not being able to update "Animation" f/w on the SOP, and then was stuck in an "Updating Loop" where it would "load the firmware" restart the machine, and then repeat.
                    Ricoh informed me of the reset sequence you mentioned. It worked the first time, but a week later the same thing happened and replacement of the Panel was necessary.
                    Omertà
