Those $#%@#% foam rollers on ricoh finishers.
  • tonerhead
    • Sep 2009
    • 582
    Has anyone ever found a rubber roller that fits the hub of the foam gathering rollers? They wear down much too quickly.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • mikadonovan
    • May 2008
    • 2931
    Re: Those $#%@#% foam rollers on ricoh finishers.
    Yes. I have used the rubber from Katun feed/pickup roller kits cut thin and then superglued onto the foam roller hub. They have to be thin or the friction from rubbing on the metal plate below it will stall out the motor that drives the foam rollers. I have done this a couple of times when I was in a pinch, and they lasted until I could install the OEM again.. It did not work as well as the foam, but good enough to mention it. Thin as in 3mm or so.
    NEVER ASSUME ANYTHING
    • anothertech
      • 1769
      They are easy to replace, just check them on the 600K pm.
      • skinnyb
        • Jul 2008
        • 291
        Same here. I carry a 6 pack and just replace when the finisher starts knocking...
        Sent from my LM-V405 using Tapatalk
        • tonerhead
          • Sep 2009
          • 582
          I guess my frustration is every other finisher has a different style hub. It wouldn't be so bad if they all used the same. Plus it always seems that I lose the white keeper while changing. Boss doesn't like me to carry all of the various styles. What I was hoping for is something universal. Oh well, the search continues. If I ever do find anything, I'll post back.
            • 37489
            Those nylon clips are a major pain. You either lose them or they break.
            • fshead
              • 2376
              just carry a bunch of clips and spares..it is not like they weigh much..
              I myself like the ricoh sorters outside of having to reform the entrance guide when i pick up
              lease returns..I get good yield out of the foam rollers..i also set normal copies to come out of the top tray NOT the shift tray
                • 37489
                lease returns..
                That is usually the result of a customer employee using them as a lift point when they moved them out to the shipping dock.
                • Codex
                  • May 2008
                  • 704
                  We bought 30 cinese rollers from alibaba, just for test... They are harder then the original rollers,and much cheaper... Till now no problems..
                  Inviato dal mio SM-G935F utilizzando Tapatalk
                  Memento Audere Semper
                  • fshead
                    • 2376
                    YEAH sometimes but i think these trucker pack the sorters in with the bottom tray still attached and clamp them too tight.......
                    It is usually bent in ..sometimes a PITA to reform correctly
                    • mrwho
                      Major Asshole!
                      • 4299
                      Rubber bands can work wonders in a pinch.
                      Mascan42
                      Ibid
                      • mikadonovan
                        • May 2008
                        • 2931
                        That is an excellent idea.
                        • qbert69
                          • Mar 2013
                          • 1152
                          Here's some I 3D Printed with TPU...Sound kinda funny on the metal plate!!![emoji23][emoji1787][emoji38]...if doing again I'd probably try NinjaFlex!!![emoji41][emoji1303]
                          Sent from my SM-N950U1 using Tapatalk
                          REACH FOR THE STARS!!!
                          Konica Minolta Planetariums!
