PROBLEM RICOH MP C5502
    • 8144
    Re: PROBLEM RICOH MP C5502
    I think this depends what your country/voltage is.
    • tullio
      • Feb 2012
      • 268
      [QUOTE = BsK; 1504729] Stai utilizzando toner Ricoh originale? SI
      • TonerMunkeh
        Professional Moron
        • 3865
        In the UK it's D142 4273 for the 3002/3502 and D144 4273 for the 4502/5502, I'm bloody sure of it :/
        Hit it.
        • solorajder
          • Jul 2010
          • 106
          #19
          The sleve unit 4502/5502 have different fusing lamp as 3002/3502, fusing lamp have more wats.
          Just take a fusing lamp from 4502/5502 sleve unit and replace it.
          I've done this a couple of times.
          Sent from my G8441 using Tapatalk
          • fshead
            • 2376
            #20
            Originally posted by tullio
            is the oven of the ricoh mpc 3502 the same as the ricoh mpc5502?
            no
            35 cpm vs 55 cpm
            • fshead
              • 2376
              #21
              plus it is not an OVEN.......Fuser has been the name a long time.............or heater unit.......
              • tsbservice
                Field tech
                • 8016
                #22
                Common language mistake when you are using translator.
                Remember at CTN we are not all born English speaking.
                  • 37491
                  #23
                  How many remember the old Royal RBC1, also sold under the Apeco label. Two waffle baker type heat grids, one above and one below.
                    Originally posted by wilez
                    Weak exposure lamp or power output to lamp is not enough get full brightness. Clean and inspect optics and check SC's for exposure errors.
                    Key word..
                    CLEAN the machine!
                      Yup 31+ years in the industry.... almost ALL common brands.
                      Either fuser/fusing/fixing assmy
                      • fshead
                        • 2376
                        #26
                        i didnt think about that but true...
                        You know how some techs create new names for parts as if the original wasnt good enough..
                        "that heater thing" "that drum imagey thing"
                        • fshead
                          • 2376
                          #27
                          yikes i remember those and the sharp 710/720/730/740 ,apeco 300 with a 6000 master life and a toaster type fuser and the paper was transported on chains.............
                          these new techs dont know how weird this industry was in the beginning
                            • 37491
                            #28
                            Do you remember which Sharp it was that used 2 cold pressure steel rollers to fuse the toner and made a clicking noise as the trail edge of the paper exited the "fusing" rollers. Gave everything a glossy finish.
                            • fshead
                              • 2376
                              #29
                              IT HAD TO BE A ELECTROSTATIC PAPER UNIT LIKE THE MITA 900D IF MY MEMORY IS WORKING WELL.
                              ALL I KNOW IS THEY WERE SUPER HEAVY AND NO HANDLES..............
                              i DROPPED A UNIT IN AN OFFICE WITH TILES..DID A LOT OF DAMAGE
                                Oooops. [emoji848][emoji1786]
