mpc5503 with sc541-02
  • hanspeter75
    • Mar 2010
    • 37
    fuser station complete revises no success, new fuser station ok but several times a day sc541-02 (NC sensor interrupted)
    Wiring harnesses checked and replugged...no way
    an idea before I replace bcu /ipu and fuser drive gear?
  • mikadonovan
    • May 2008
    • 2936
    Re: mpc5503 with sc541-02
    Why don't you just replace the non contact sensors?
    37.AW100150
    NON-CONTACT TY
    PE THERMISTOR:
    NC-F10:MIDDLE
    38.AW100151
    NON-CONTACT TY
    PE THERMISTOR:
    NC-F10:FRONT
    NEVER ASSUME ANYTHING
    • Zaxxon
      • 608
      37.AW100150
      NON-CONTACT TY
      PE THERMISTOR:
      NC-F10:MIDDLE
      38.AW100151
      NON-CONTACT TY
      PE THERMISTOR:
      NC-F10:FRONT
      Would be to easy, never trust the SC!!!
      Please start you post with brand, model, problem.
      • hanspeter75
        • Mar 2010
        • 37
        'm not changing the nc sensors on a new station... they should work
        fuser now replaced with a complete used unit...now works
        will then test the existing new unit with the nc-sensors when they are delivered.
        greetings
        • skinnyb
          • Jul 2008
          • 291
          greetings
          I've seen wiring issues more of a problem than the sensors themselves. Always a really old unit though, never had a bad one out of the box...
          Sent from my LM-V405 using Tapatalk
          • anothertech
            • 1755
            Before you change any PCB's, inspect the ITB for rips, clean the ITB unit, could be arcing. Also check the power outlet, dose it have a surge protector that records power events?
            • hanspeter75
              • Mar 2010
              • 37
              the problem seems to be solved after 1 week test run with a new replacement heater. the first one was "new defect" ...no idea why
                • 22801
                in 31+ yrs in the industry, I've had ALL brands that the new genuine oem fusers FAILED out of the box.
                they are assembled by HUMANS therefore there is a margin of error built into the product
                "shit happens"
                  • 36689
                  The proper term is "Out Of Box Failure"
                  • FrohnB
                    • Jul 2017
                    • 1919
                    With the Cxx03 series fusers, we had to resort to ohming out the lamps on all new sleeves. We had a batch come in where 5 out of 10 had broken lamps shortly after the release of this series.
                    Still receive one occasionally that has the lamp broken. Usually just take the lamp out of the old one and put in the new one if that's the case.
                    Omertà
