Ricoh mpc400 please wait message on panel
  • Oze
    Ricoh Fanboy
    • 1663
    Re: Ricoh mpc400 please wait message on panel
    Actually Ricoh does not erase all the data, that would take too long. All it does is erase and rebuild the indices and allocation tables so the data cannot be found.
    And THAT'S why formatting the HDD alone doesn't always resolve the issues...only replacing it.
    But if he's tested the machine with no HDD at all and it's still sitting on "Please wait" then it's most likely as Slim stated...an App stalled.
    Or at worst the Controller PCB.
    • solorajder
      • Jul 2010
      • 106
      he gets the error with/without it connected... formatting a HDD loses ALL info stored on it...
      frankly I think he should disable all aps and go from there.
      if he formats it he will need to reload firmware
      your profile is missing LOTS of vital info... ARE you a trained RICOH tech? How many years in the industry? did you read the S Manual?
      All data in yours profile is irrelevant if you don't know that when you replace the hd on ricoh machine you don't need to reload firmware.
      Sent from my G8441 using Tapatalk
        • 37494
        Apparently you do not know anything about Java applications on Ricohs. Many of them are ran from the HDD. Others store data on the HDD that if lost, as a result of formatting the HDD, will require installing the app again.
        • solorajder
          • Jul 2010
          • 106
          #19
          If you looked in service manual for MPC 400 under installing new hdd, there is nothing about java.
          • UNICORNico
            • May 2018
            • 308
            #20
            Originally posted by Jama
            [ATTACH=CONFIG]46216[/ATTACH]The mpc400 displaying please wait message/panel, I disconnected fax options, hdd, also checked RAMS, but still shows please wait message on panel, at some point it displayed sc997, could this be firmware in need? any link/site for firmware down?
            I'm sorry to let you know that you may have a "BICU" problem
            Not long ago, we suffered a similar problem with an MP C4502, did not boot the system, did not allow access to SP MODE, and only showed a SC 99x.
            If you've tried disconnecting HDD, FAX, and USB ports from the Operations Panel. Another recommendation I can't make.
            "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
              • 37494
              #21
              Most JAVA apps are written by third parties and as such are covered with the documentation that comes with the JAVA app, not the service manual.
              Also when you reinstall Dara Overwrite Security Unit, HDD Encryption Unit or ELP NX you are reinstalling the firmware for those apps.
              • solorajder
                • Jul 2010
                • 106
                #22
                MPC400 is an old unit, I doubt that he have installed Overwrite Security Unit, HDD Encryption Unit and ELP NX.
                  • 37494
                  #23
                  I was only quoting what you posted. Are you saying that the information you posted did not come from the MPC400 service manual as you claimed when you posted it?
                  By the way, MPC 305 is an even older unit. It has HDD Overwrite, HDD Encryption and Secure Print available for the optional HDD.
                    look at his non-existent profile... rep points.
                    he KNOWS he's right even with proof to him being wrong...
                    another on my iggy list.
                    • solorajder
                      • Jul 2010
                      • 106
                      #25
                      Is it slimslob your boss or your boyfriend that you can"t stop kissing his ass.
                      Look... I just give a Jama a tip what would I do first. I have simular problems and I solved it with hdd format or change it with new one on a few devices.
                      Why you two have to discard everyone who doesn't think as you two? Slimslob and I give him a tip now let him decide for himself what he will do.
                      I don't care if I'm on your iggy list....you and slimslob have been on mine for a long time.
                      Have a nice day.
                        Have a nice day.
                        you really love to push an issue.
                        he is neither my boss ( he is in CA I'm in NC but if you look a profiles you would know that fact)
                        we don't discard everyone just jackasses. we both have close to 70 years combined so that proves to me that we know what we are talking about most of the time.
                        the thing about profiles ( properly filled out ) this gives us senior techs a look into a users abilities ... those that don't fill in the information leaves us guessing as IF the user has been formally trained on Brand/Model of machines.
                        and to block a user like SlimSlob just shows ignorance on your part... he is one of the most knowledgeable Ricoh techs here.
                        • Jama
                          • Jul 2020
                          • 49
                          #27
                          Yap, it seams to be Controller PCB...Maybe firmware will sort this
                          • solorajder
                            • Jul 2010
                            • 106
                            #28
                            As you sead... most of the time.
                            • Jama
                              • Jul 2020
                              • 49
                              #29
                              Thanks for suggestion, the problem seams to be controller/BICU, will be fixing same and see whether the problem will be sorted. Today I replaced new hdd but nothing happened, still showing ''please wait message''
                                wow sead? you mean said ...
                                whata loser.
