mpc 5502 double imaging
  • digicor
    • Jul 2008
    • 1153
    I have replaced the k drum several times, the double imaging is in the k drum,, fuser is near new, and i know what that looks like.. lol
    if i have the client print in color it does not do it EVER at all
    it obvious it the k drum unit the double imaged text is the same diameter as the a drum.. and i replace it,, it goes away for a week or two then comes back, ive cleaned the charge roller, connections etc..
    has some one had this problem? its the only one i have thats doing it...cant figure it out...any clues? thanks
  • mrwho
    Major Asshole!
    • 4299
    Re: mpc 5502 double imaging
    If it doesn't do it in color, then it most likely is not a mechanical problem - I'd wager on some adjustment that applies only to K prints.
    Try to back up the NVRAM, clear the engine settings and try it out for a while to see if it still happens before restoring the backup.
    Mascan42
    Ibid
      • 37393
      Try making the adjustments in the attached. It will slightly reduce toner concentration in the developer thereby putting slightly less toner on the drum and compensates by pulling more of the toner from the drum to the ITB. Service Program (SP) Settings.pdf
      • davel
        • Oct 2011
        • 1095
        Try making the adjustments in the attached. It will slightly reduce toner concentration in the developer thereby putting slightly less toner on the drum and compensates by pulling more of the toner from the drum to the ITB. [ATTACH]46350[/ATTACH]
        Did you replace all PCU PM parts or just the drum.
        • copier tech
          • 8131
          Are you using the correct PCU (Genuine Ricoh) & Genuine toner?
          • digicor
            • Jul 2008
            • 1153
            yes whole PCU three times from other good working machines
            • digicor
              • Jul 2008
              • 1153
              Yes always
              • copier tech
                • 8131
                There is your answer. Fit a new PCU.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  +1...time to stop trying to save a quid on an account
                  Also print out the non default settings to see if anybody has dicked about with settings related to the K pcdu.
                    • 37393
                    PCU offsetting is often caused by too much toner being applied to the drum to the point that the cleaning blade cannot keep up. Frequently it is caused by the developer being slightly over toned. When you swap a PCU or even a PCDU you don't do anything to change what ever is causing the over toning.
                    I had a customer one time called that they were getting red spots. When I got to their location they were trying to print brochure for their gun club. The front page had a picture of a hunter on a hillside wearing a bright red cap. The color of the cap was being offset four to six more time down an 11X17 sheet. Making the adjustments in the document I posted earlier cleared the problem.
                    • digicor
                      • Jul 2008
                      • 1153
                      new PCU did not solve the problem, i did some Blk adjustments as instructed from one of the posts yesterday , they have a huge print job today, and this will see if the adjustments worked
                      i will keep u posted
                      • digicor
                        • Jul 2008
                        • 1153
                        UPDATE so far the adjustments ive made have held steady, and i have no call backs on the dbl imaging, they have ras a big print job, no probs
                        Thanks guys
