sc816-36
  • babu
    • Apr 2018
    • 19
    sc816-36
    Hello Guys ! I have a problem sc816-36 in ricoh MP2501SP, When machine is ready and starting copy 4 or 5 copies then error messege sc816-36. Plz Help
    Re: sc816-36
    what have you done to correct it?
    • babu
      • Apr 2018
      • 19
      Re: sc816-36
        • 37386
        Re: sc816-36
        Do you have a service manual and if so have you checked it?
        MP 2501 SC816-36 Energy save I/O subsystem error.
        Energy save I/O subsystem detected some abnormality.
        • [*=1]Energy save I/O subsystem defective
          [*=1]Energy save I/O subsystem detected a controller board error (non-response).
          [*=1]Error was detected during preparation for transition to STR.
          [*=1]Turn the main power off/on.
          [*=1]Replace the controller board.
        • copyaction
          • Oct 2007
          • 985
          Re: sc816-36
          You can also try removing the fax and the hdd if it has them.
          • anothertech
            • 1762
            Re: sc816-36
            See if you can turn off energy save.
            • copier tech
              • 8131
              Re: sc816-36
              Try disconnecting the HDD & Fax & see if the error clears with the LAN cable not plugged in.
              While you have the back off reseat all the connections & ram etc.
              Its also worth updating the firmware before you replace any boards.
              • JaysOnTheEDGE
                • 61
                Re: sc816-36
                Are you a technician or a end user?
                  Re: sc816-36
                  it's hard to tell from his profile:
                  About babu
                  Real Name:shorabCountry:BangladeshWhere are you from (City, State):dhakaBiography:I am engineer of calculator bangladesh limited , As a senior enginner of this company,Interests:Find troubleshooting, try to resolveWhat Year Did You Start in this Industry:2012Most Hated Brand:ricohWhat was the first machine you worked on:4000B,5054spLast machine you were formally trained on:5055spGender:Male
                    • 37386
                    Re: sc816-36
                    About babu
                    From his statement "I have a problem" and not I have a customer with a problem, I take it that he IS an end user or the employee of an end user company.
