MPC3002 SC571-00
  • sostek
    • May 2010
    • 81
    MPC3002 SC571-00
    Hi all, I've got this MPC3002 with error SC571-00. 5810 doesn't reset and the PR thermistors are pretty torn up. Just wondering if the thermistors are a probable fix and is there a spacial procedure for this model. I'm familiar with ricoh color through MPC5000. These seem to behave a little differently.
    Re: MPC3002 SC571-00
    which 5810-??? did you use?
    what happened to kick this error?
    did your customer use INK JET PAPER? ( a no-no in toner based life forms.)
    please provide more info
    • mikadonovan
      • May 2008
      • 2925
      Yes , replace the thermistors. Actual fuser temp can be checked in sp mode 1106 to identify which thermistor has failed. Code is cleared by 5810-002, IF it has a new reset fuse installed in the fuser. These fuses come with a new fusing sleeve.
      NEVER ASSUME ANYTHING
        • 37711
        Just remember, if the cause of the SC has not been corrected, it will immediate error again.
        As mika said, a reset fuse is included with a new fusing sleeve. When you replace the sleeve during scheduled and not because of an error you do not need the fuse. Put in your spare parts kit. Then when you have a repairable error, you have a reset fuse.
        • sostek
          • May 2010
          • 81
          Tried both 5810 to no avail. As far as anyone knows code just appeared, no fuser damage other than the thermistors seem worn through. I have some "reset" fuses, pico. 1/16 A. Do I need the fuse as well as thermistors?
            • 37711
            YES
            • copier tech
              • 8285
              If you have had the fuser apart it is possible to accidentally bend the thermistor away from the pressure roller it will then throw this error.
              Personally I would replace the fuser sleeve & thermistor & also the pressure roller if it looks worn especially around the area the thermistor makes contact.
              • Code: 571-00
              • Description:Causes:Remedy:1. Check if the thermistor is firmly connected. 2. Replace the center thermistor.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                • Code: 571-00
                +1
                Regards Mark
                  Originally posted by mga
                  +1
                  IF he tried both 5810-xxx then i hope he has the birth cert or he's in for a world of hurt.. a rookie move for not having/reading the manual before any work was done
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    You should always carry the correct tools and information.
                    Regards Mark
                    • davel
                      • Oct 2011
                      • 1112
                      5810 is SC reset, you assumed he said 5801, please read post again.
                        thanks for the correction.. fat fingers
