Ricoh mp2501 back side lines
  • senakainoki
    • Nov 2019
    • 25
    [CQ] Ricoh mp2501 back side lines
    Hi,
    35.000 Copies has taken Mp2501 new machine, front side is perfect but back side equal line will appear 5mm.. Customer using original toner..I have change development bias also.... same problem......Any body face this problem,,,,
    • 37560
    Re: Ricoh mp2501 back side lines
    Back side lines could from PTR, fusing unit pressure roller or paper guide ribs.
    • davel
      • Oct 2011
      • 1108
      Sample of the line please, put bias setting back to normal, how is that supposed to fix a line.
      • senakainoki
        • Nov 2019
        • 25
        I have attached sample copy pls check
          the attachment doesn't open
          • senakainoki
            • Nov 2019
            • 25
            Please check now
            • ThePomqueteer
              • Sep 2016
              • 73
              I would replace drum next if PTR doesn't fix. Looks like what the 301 does when the drum is starting to go on it. Usually only does it for the first few pages of a job.
              • senakainoki
                • Nov 2019
                • 25
                Please check now
                Please check the sample copy
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  PCU needs rebuilding.
                  Hit it.
                  • Polo-022
                    • Sep 2007
                    • 486
                    Replace Drum, Developer, Charge roller cleaning roller and Cleaning blade.
                    Unfortunatelly this model does not reach PM target.
                    And yes i am facing it, very often!
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      That looks like the ptr change the developer and any other parts within pcu make sure mag roller is clean before you replace developer then set up also make sure all filters are clean and vac or blow toner from machine
                      Regards Mark
                      • KeviM
                        • Oct 2019
                        • 327
                        I have to agree with the other guys, change your Dev, drum and cleaning blade. Make sure you do the developer initialization.
                        Also clean your reg roller and reg roller cleaner.
                        And 1 more thing on your PCU, the plastic part of it that sits just above the reg roller and below the mag roller , put a strip of tape on it from left to right.
                          • 37560
                          If that is the lead edge, you definitely have a dirty PTR.
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            Which paper has been used in that machine?
                            Very thick paper - or / and - no copy paper?
                            • charm18
                              • Apr 2017
                              • 5
                              Hi,
                              need to replace parts opc drum, cleaning blade, dveloper,, after u replace see if ok
