MP C307 SC PROBLEM
  • hosennet
    • Mar 2007
    • 145
    MP C307 SC PROBLEM
    Hi All
    MP C307 Display SC992-00
    Help Me Please !
    Re: MP C307 SC PROBLEM
    Originally posted by hosennet
    Hi All MP C307 Display SC992-00 Help Me Please ! Thanks
    that SC error is clearly defined in the service manual.
    if you don't have it request it here ---> https://www.copytechnet.com/forums/s...nual-requests/
      • 37538
      Did you try to update firmware on your own? If so you may have cratered the machine./
      • copier tech
        • 8179
        Hi All
        Help Me Please !
        Try updating the firmware with the latest package.
        • Code: SC992-00
        • Description:Undefined SC issued
          An SC, that is not controlled by the system, occurred.
        • Causes:Remedy:Cycle the main power OFF/ON.
        • anothertech
          • 1771
          This machine can update firmware automatically if the machine in on a network and has access to the internet. Change SP5886-111 from 0 to 1 then give it a few days and it will auto update. That is assuming you have gotten the SC992-00 to clear.
          • Babujoseph
            • 35
            Did you update firmware ?
            • hosennet
              • Mar 2007
              • 145
              Yes
              SYMPTOM
              SC992 occurs frequently.
              Note: SC992 also appears as SC816-98 (logged SC) on the SMC.
              CAUSE
              The controller freezes (internal processing cannot continue) if the machine receives a
              certain type of network data packet from mDNS while in Energy Saver mode.
              SOLUTION
              Update the PowerSaving Sys firmware to the modified version or later.
              Firmware Name P/N Version
              PowerSaving Sys D2965783A F.L3.06.1
              No Update
              PowerSaving Sys F.L3.06 D2965783
              • copier tech
                • 8179
                Yes
                SYMPTOM
                CAUSE
                SOLUTION
                No Update
                Did updating this power saving firmware resolve your issue?
