Mp 4000 adf papaer jam problem
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    [Jamming] Mp 4000 adf papaer jam problem
    Hi friends my machine MP4000 ADF showing paper jam even after i take out the jam paper how to solve this problem friends
  • GIUBOSS
    • 1435
    Re: Mp 4000 adf papaer jam problem
    What is the jam code? Did the removed paper have pieces missing? Remove all paper trays and check inside; did you reset by opening and closing all the doors?
    • ThePomqueteer
      • Sep 2016
      • 73
      +1 and if the pages don't seem to have pieces missing the next thing I'd check is the sensors. Sounds like a possible dirty sensor(s).
      • kanagavel
        Service Engineer
        • Feb 2020
        • 78
        Hi friends thanks to all of you for the reply, i solve the problem already. The solution is the ADF pickup timing pulley gear cracked so i modified that gear then its working fine. Thank you.
