MPC2003 Won't wake up from sleep.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: MPC2003 Won't wake up from sleep.
    You have this list in the wrong order.
    Update ALL firmware, then java before you start clearing anything.
    I prefer to update firmware after clearing parts of nvram etc it's never given me any problems unless you can tell me what the difference would be.
    Regards Mark
      • 8195
      Quite simply because its the quickest & easiest first step to update firmware before clearing settings & as you you say "Reset up machine from scratch"
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        I thought he's tried all that but I may be wrong.
        Regards Mark
        • Chummy
          • Mar 2016
          • 8
          #19
          After again checking the firmware was up to date, I changed all time out settings, turned off Java and rebooted machine. Still machine wouldn't wake up from sleep. I then tried to do a complete reformat of the HDD, the screen just froze for ever and a day. After rebooting the machine I then formatted each partition of the HDD in turn, rebooted again. You've guessed it - normal operation has resumed !!!!!!
          Many thanks to all for your contributions.
          • Gift
            • Mar 2011
            • 2459
            #20
            thanks for getting back with your feedback
            • Oze
              Ricoh Fanboy
              • 1663
              #21
              One other step for machines that are having issues waking from sleep is to turn off STR mode SP5-191-001.
              • mikadonovan
                • May 2008
                • 2931
                #22
                I had never heard of this sp. I checked the c6003 right next to me, and that sp is on that machine. However, I looked in the manual for a more detailed description, and it is not in there. Must have been added in a firmware update.
                NEVER ASSUME ANYTHING
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  #23
                  Hi mikadonovan
                  It is in the latest sm
                  Regards Mark
