Does anyone have a solution for a problem I am having with an Ricoh MP C2003. The machine works well during normal operation. When it goes into sleep mode the machine won't wake up when either a print job is sent, the DF is lifted or a document is placed on the feeder. The control panel is also inoperable until the machine is turned OFF/ON when normal operation carries on until sleep mode starts again. Lapsed firmware has been updated and the controller board swapped with one from another machine. Any suggestions will be appreciated.
MPC2003 Won't wake up from sleep.
Re: MPC2003 Won't wake up from sleep.
Have you power cycled the machine?
If you did, my next step would be firmware. -
Last edited by BillyCarpenter; 09-28-2020, 05:51 PM.Adversity temporarily visits a strong man but stays with the weak for a lifetime.Comment
There was a bulletin on this specific issue.
To be fare to ThePomqueteer, I did edit the question whilst receiving the quick reply.
I have updated the firmware using the romdata method.
The timer settings are set as follows :- Sleep mode 60 mins
System, Copier, Print & Scanner Auto reset 60 secs
Auto logout 240 secs
Fuser OFF mode is off.
Which bulletin relates to this problem ?
Many thanks for the replies so farComment
I usually turn off JAVA with SP 5730 set to 0 this can help with various issues.
See attached page 107
Troubleshooting Bulletins.pdfLet us eat, drink, and be merry, because tomorrow we may die!
That troubleshooting document would be much more useful if someone would remove all of the entries that relate to firmware. Then they could just say "Update firmware and if still a problem, refer to the document."Comment
I would do all this
Reset in factory 58xx 0x6
Format hdd
Clear nvram all apart from 1&2
Reset up machine from scratch
Turn of java
Update all firmware
If you need java update java firmware
Good luckRegards Mark
https://copierservices.simdif.comComment
Update ALL firmware, then java before you start clearing anything.
