MPC2003 Won't wake up from sleep.
  • Chummy
    • Mar 2016
    • 8
    Does anyone have a solution for a problem I am having with an Ricoh MP C2003. The machine works well during normal operation. When it goes into sleep mode the machine won't wake up when either a print job is sent, the DF is lifted or a document is placed on the feeder. The control panel is also inoperable until the machine is turned OFF/ON when normal operation carries on until sleep mode starts again. Lapsed firmware has been updated and the controller board swapped with one from another machine. Any suggestions will be appreciated.
  • ThePomqueteer
    • Sep 2016
    • 73
    Re: MPC2003 Won't wake up from sleep.
    Have you power cycled the machine?
    If you did, my next step would be firmware.
      • 37561
      You obviously did not read all of what Chummy posted.
        • 16455
        Or any of it.
          • 37561
          If firmware is up to date, check all time out settings. Multiple settings being exact the same can cause problems.
            • 8195
            What firmware did you update, the package or using the romdata method?
            There was a bulletin on this specific issue.
            • Chummy
              • Mar 2016
              • 8
              To be fare to ThePomqueteer, I did edit the question whilst receiving the quick reply.
              I have updated the firmware using the romdata method.
              The timer settings are set as follows :- Sleep mode 60 mins
              System, Copier, Print & Scanner Auto reset 60 secs
              Auto logout 240 secs
              Fuser OFF mode is off.
              Which bulletin relates to this problem ?
              Many thanks for the replies so far
                • 8195
                OK, so which files did you update? Theres about 20.
                • Chummy
                  • Mar 2016
                  • 8
                  The files updated are :-
                  Engine v 1.33:01
                  Net Support v 12.94
                  OpePanel v 1.15
                  PDF v1.06
                  Printer v 1.15
                  Scanner v 01.14
                  SysCopy v 1.30
                  Web Support v 1.13
                  Web Uapl v 1.06
                  All other firmware is up to date.
                  • ThePomqueteer
                    • Sep 2016
                    • 73
                      • 37561
                      I have had strange problems when all three were set the same. Gets even worse when auto logoff is also set to the same time.
                        • 8195
                        Engine v 1.33:01
                        Net Support v 12.94
                        OpePanel v 1.15
                        PDF v1.06
                        Printer v 1.15
                        Scanner v 01.14
                        SysCopy v 1.30
                        Web Support v 1.13
                        Web Uapl v 1.06
                        What version is your power Saving sys on?
                        I usually turn off JAVA with SP 5730 set to 0 this can help with various issues.
                        See attached page 107
                        Troubleshooting Bulletins.pdf
                        • anothertech
                          • 1771
                          [ATTACH]46903[/ATTACH]
                          That troubleshooting document would be much more useful if someone would remove all of the entries that relate to firmware. Then they could just say "Update firmware and if still a problem, refer to the document."
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            I would do all this
                            Reset in factory 58xx 0x6
                            Format hdd
                            Clear nvram all apart from 1&2
                            Reset up machine from scratch
                            Turn of java
                            Update all firmware
                            If you need java update java firmware
                            Good luck
                            Regards Mark
                              • 8195
                              Originally posted by mga
                              I would do all this
                              Format hdd
                              Turn of java
                              Update all firmware
                              Good luck
                              You have this list in the wrong order.
                              Update ALL firmware, then java before you start clearing anything.
