MP9002 Jamming on tray 1
  • Keegan Chetty
    • May 2015
    • 113
    #16
    Re: MP9002 Jamming on tray 1
    Forget about the damned jam letter. That is merely to tell the operator where to look for the jam. What is the actual jam code, displayed in the form Jxxx where xxx is a 3 digit number. It tells us whether the jam is detected by the relay sensor or the registration sensor and whether it is a late jam of a lag jam. An actual paper tray jam would be an operator letter of A, not B.
    it looks like it folds as soon as it leaves the tray but gets stuck in the b guide area
    • skinnyb
      • Jul 2008
      • 291
      #17
      I would check the tray itself. I have seen when the paper is stacked crooked or a stack of sheets folded under on one corner it causes this. If the sheet table is crooked or an issue with the cables not lifting uniformly it will do this... I usually run the table cable lift up and down by hand and measure with a tape and see that it is square and level. Those cables sometimes have a mind of their own.
      Sent from my LM-V405 using Tapatalk
      • Keegan Chetty
        • May 2015
        • 113
        #18
        thank you, I've tried replacing the entire tray including the A guide plate, I wonder if the actual rail for the tray could be the issue
        • Notrons
          • Apr 2016
          • 71
          #19
          Originally posted by Keegan Chetty
          It's only tray 1, tray 2 and 3 work with no issues at all
          You can swap one of the working paper feed units from either tray 2 or 3, they are all the same. If the problem follows, you can narrow the problem to the paper feed unit. I did get a good look at the one I was working on, it kind of looked like one of the tension springs needed replacement. Unfortunately, was unable to find part, so just replaced entire feed unit.
          • Keegan Chetty
            • May 2015
            • 113
            #20
            thank you, I haven't swopped from to or 3 but I did try 2 other feed stations from other machines. Will definitely try sopping tray 2 with 1
              • 37489
              #21
              What width paper is being fed from trays 2 and 3?
                • 37489
                #22
                it shows relay sensor: late and jam J012
                I wonder if there might actually be 2 problems. One causing the fold. The other causing the jam. Otherwise the fold and delay are happening in the paper path somewhere between transport sensor 1 and the relay sensor.
                • Keegan Chetty
                  • May 2015
                  • 113
                  #23
                  All being fed same as tray 1. A4 long edge feed
                  • Keegan Chetty
                    • May 2015
                    • 113
                    #24
                    but how? I've changed the whole reg unit as well as the A guide and the feed station and the other trays go through the same paper path. Where else could the issue be? Perhaps a board?
                      • 37489
                      #25
                      My guess would be a burr on the plastic flip down turn guide coming out of the tray 1 feed station. It is close enough to the 1st transport sensor to not have delayed the paper enough to cause a J008 as the fold could be in the middle of happening. Far enough from the relay sensor to have delayed it enough to be detected as a jam J012. If that is the case, if you swap feed stations 1 and 2 the fold will still be there and the jam might change to J008.
                      • Keegan Chetty
                        • May 2015
                        • 113
                        #26
                        Thanks for the info I will definitely go back and see what's going on around that area
                        • Keegan Chetty
                          • May 2015
                          • 113
                          #27
                          UPDATE: I have swopped tray 1 and 2 feed stations around and ran 15k copies and no jams. I don't know how that's possible.Thanks to everyone for the assistance.
