Ricoh IMC4500 Translucent Paper Print Quality
  • Batman1976
    • Jun 2016
    • 91
    [CQ] Ricoh IMC4500 Translucent Paper Print Quality
    Hi All,
    We recently sold an Ricoh IMC4500 with fiery controller and the client wishes to print heavy black solids on backlit/translucent paper (frosted). The quality of the Black solid when put on the back light is some what disappointing, it appears a washed out charcoal grey. Apparently the previous machine (A Canon) done the job fine.
    I have tried various paper thickness settings on device and different print output profiles through the command workstation software including photographic, print as true black etc and it still produces the same result.
    My last resort is to try adjusting the paper transfer bias on the machine? Before I do this has anyone got any other suggestions?
    Many Thanks guys
    Batman1976
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh IMC4500 Translucent Paper Print Quality
    If it's not working because of the media, change the media. That may not be what they want to hear, but the customer is NOT always right. It would be in your best interest to find an acceptable media that works better, then show them.
    NEVER ASSUME ANYTHING
    • Mark Bbb
      • Jun 2012
      • 1662
      I agree.
      If the image is fine when printed on normal - or even (very) thick - paper.
      Perhaps this media is moistured in a way?
      • skinnyb
        • Jul 2008
        • 291
        Solid fills on the newer Ricoh (MP C 6004, IMC 6000) are not near as full as they used to be. It is what it is. I have had customers with these engines and this has been a problem, especially those sold with Fiery and are trying to do "production" work out of a basic business color machine. Just because if has a fiery doesn't change the fact that the engine is a business color device. Last customer I had that demanded production level work ended up buying a Pro 5300 production device.
        Sent from my LM-V405 using Tapatalk
        • DRichard
          • May 2008
          • 482
          +1
          "Enjoy every sandwich."
          -- Warren Zevon
          • StephenB
            • Aug 2015
            • 244
            If your client is using a graphic program for their graphics, note...you are using a 4 color process CMYK. Black 100% K is NOT a deep rich black. to get a deep rich black set the CMYK settings to to C = 60 M=40 Y=40 K=100
            These are graphic program settings, the Ricoh just prints what the program tells it.
            If their "black" in their program is anything else, it will be washed out.
            • Mark Bbb
              • Jun 2012
              • 1662
              perhaps better results with Post Script?
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Ricoh's advice:
                When loading translucent paper:
                • Remove printed sheets one by one.
                • When loading translucent paper, always use long grain paper, and set the paper direction according to the grain.
                • Translucent paper easily absorbs humidity and becomes curled. Remove curl in the translucent paper before loading.
                  They might have something there about humidity.
                  Damp paper will affect transfer.
                • Batman1976
                  • Jun 2016
                  • 91
                  Thanks for responses. I'm now going down the route of getting to customer to change the media type/brand.
                  Does anyone know of a Translucent paper brand that will work well on a RICOH IMC device?
                  Batamn76
                  • mikadonovan
                    • May 2008
                    • 2931
                    I could not locate an exact brand, but this print shop has tips for printing on vellum, it may help.
                    How to Print on Translucent Vellum Paper
