technical documents - holder
  • mikadonovan
    • May 2008
    • 2931
    Re: technical documents - holder
    Originally posted by Mark Bbb
    Mika: Excel, power point or a special program?
    I just created a standard service report with Word.
    NEVER ASSUME ANYTHING
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Originally posted by DRichard
      Sorry to go off on a tangent, but I'm glad you mentioned this...We install quite a few OCR units these days and you need to store the SD card in the machine. Where is the storage slot(s) on other MFPs designed differently? I have found no storage spaces for the SD card described in other service manuals even though the installation instructions tell you to "store the SD card in the prescribed storage slot."
      SD card holder behind little panel where the on/off button is metis series it does tell you this in the installation guide for the ocr and ps3 sd cards
      Regards Mark
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Attached is storeage area
        Regards Mark
          • 37059
          #19
          That same information and illustrations is in the main service manual for the metis.
          • DRichard
            • May 2008
            • 482
            #20
            Yes. Copier Tech cited the C3003 as an example...but my question is, is there a similar "holder" on the other Ricoh MFP machines of other designs?
            "Enjoy every sandwich."
            -- Warren Zevon
              • 8121
              #21
              From the service manual.
              SD Storage.pdf
                • 37059
                #22
                Different models will have different recommended storage locations. Usually the portion of the service manual dealing with merging applications on one SD card will make reference to the location. Example this is from the service manual for the Pro 107EX "The SD card is the only evidence that the customer is licensed to use the application program. Also, the technician may occasionally need to check the SD card and its data. For these reasons, store the unused SD cards in the front cover of the main machine."
                • sandmanmac
                  • 3973
                  #23
                  Yes.
                  Search 4 words ("insert the SD card") from the example page provided, in the Service manual of just about any model, and you'll find out where they go on that particular model.
                  • luca72
                    • Oct 2017
                    • 1711
                    #24
                    Hoi,
                    Customer sometimes throw away the technical documents when they are put in the paper tray.
                    So, we use a plastic envelop , see picture (can't upload), remove the upper cover (open / close part) and stick it to the left or rear cover of the MFP.
                    But that is a waste we want to avoid.
                    Which holder do you use?
                    hi, leaving aside the fact that generally my quantum brain always remembers the parts replaced on the machines by the various customers (LOL) ... I usually apply an adhesive paper label on the replaced part, for example on the pcdu: BK = 160000 data 22/10/2020, which I consider very practical and immediate, but basic before going out, I consult our management software to get a general idea of ​​the parts replaced and the works done and their dates and quantity of prints, keep in mind that we are in two, so it is very easy to manage the history of the interventions
