sc721-42 mpc5504 sr3220
  • hanspeter75
    • Mar 2010
    • 37
    this error exists temporarily at the sorter. where is this motor on the parts catalog...? another idea what else could it be?
    gruss
    • 37052
    Re: sc721-42 mpc5504 sr3220
    Which finisher? Do not want to give you information for the wrong finisher.
    • FrohnB
      • Jul 2017
      • 1919
      SC721-42 B Stapler Retreat Motor Error
      During movement to home, the home position could not be detected withina predetermined pulse (1st time is jam notification, 2nd time is SCnotification)
      During movement from home, the home position was detected even after a predetermined pulse elapsed (1st time is jam notification, 2nd time is SCnotification)
      During movement from home, retreat sensor ON could not be detected even after a predetermined pulse elapsed (1st time is jam notification,2nd time is SC notification)
      During initialization, retreat sensor ON was detected simultaneously when the home position is detected (1st time is jam notification, 2nd time is SC
      Could be a defective motor. The only 2 motors in the staple unit area are P/N: D5865640 and D6865630.
      Could be that the stapler unit is not moving freely and is putting extra load on the motor.
      Defective Home Position Sensor for the stapler unit.
      Check if the SC occurs by opening/closing covers, and input/output check. If the SC occurs again, do the following steps.
      Check
      if the SC reoccurs by cycling the power after each step
      The target parts are the motor and related HP sensor that SC occurred.
      1. Check if the connector of the target part is connected securely. Reconnectthe connector if it is disconnected, or loose.
      2. Check the harness for the target part. Replace the harness if it is disconnected, or damaged.
      3. Check in input and output modes if the motor runs, sensors turn OFF/ON, has no overloads, and is properly driven. Replace the parts if there are any defects.
      4. Check
      if there are any signs of a short circuit. Replace the parts if there are any defects.
      Omertà
      • anothertech
        • 1757
        I've read that it can be caused by to wires going to the stapler pulling loose, caused from the stapler going back and forth. Sometimes the harness is a little short and pulled too tight.
        • hanspeter75
          • Mar 2010
          • 37
          @slimslob sr3220
          yeh....i do order the 2 motors and the wire.
          I hope it helps...let me know then
            • 37052
            Originally posted by hanspeter75
            @slimslob sr3220
            If you have the C5504 service manual both the motor and the retreat sensor are shown in the Stapler displacement mechanism portion of the section on the finisher. I hope that is one of the motors you ordered. The sensor could also be the problem.
            • Zaxxon
              • 608
              Check if the lock pin is bend (the one holding the unit locked when paper jammed).
              Please start you post with brand, model, problem.
              • hanspeter75
                • Mar 2010
                • 37
                I do not quite understand?
                • Gift
                  • Mar 2011
                  • 2457
                  I'll give the stapler harness a +1, we had quite a few ones going faulty
                  • Zaxxon
                    • 608
                    There is a little metal pin/pahl holding the entire drawer locked, when machine runs. This pin can be bend and cause sc721-42
                    • hanspeter75
                      • Mar 2010
                      • 37
                      do you mean this one?
                      • Zaxxon
                        • 608
                        Yes, if this is bend it can get caught the black plastic things and make this error.
