mp c4503 white dots
  • Marwanalhajbi
    • Jul 2018
    • 72
    mp c4503 white dots
    greetings for everyone
    i have issue a white spots on black as shown,i have changed the whole black pcdu no results,
    any suggestion please
    The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
  • copier tech
    • 8174
    Re: mp c4503 white dots
    https://we.tl/t-eJm8wS6C4w
    What is the life of the PTR & primary transfer unit?
    What does say cyan solid look like?
    I'd start by replacing the PTR.
    • 8T2
      • Aug 2015
      • 257
      I would try a different Paper Transfer Roller (Transfer/Seperation Roller)
      Sent from my WAS-LX1 using Tapatalk
      • 8T2
        • Aug 2015
        • 257
        Haha dammit beat me to it by seconds
        • copier tech
          • 8174
          You snooze you loose!
          • FrohnB
            • Jul 2017
            • 1919
            BLACK TRANSFER ROLLER IN ITB UNIT.
            Have had this many times on this series and the Cxx02 series, and all the way back to the C4000/C5000 series.
            EDIT: I don't think this is a part that is available to order.....we've always had to either swap the ITB unit, or pull the black transfer roller from a unit in a graveyard machine.
            Omertà
            • tonerhead
              • Sep 2009
              • 582
              Seen that before on ITB. As mentioned it is the black primary charge on itb. Part number is in the partsfinder for the machine. Don't know if proper to list part number on forum, but I did check in partsfinder and it was listed.
              I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
              Especially when it comes to sex
              • anothertech
                • 1771
                I don't see any problem posting a part number.
                This looks like it,
                D1496336
                (x4)
                TRANSFER ROLLE
                R:ASS'Y
                • Marwanalhajbi
                  • Jul 2018
                  • 72
                  thank you so much
                  • Blizzoo
                    • Aug 2013
                    • 608
                    As mentioned the 1st transfer roller in ITB unit is likely causing this. Not sure if possible but if you swap the 1st transfer roller let's say from K with Y the fault should move with the roller and you may get a good print quality (the spots may be less noticeable on Y side) until you got a new ITB unit replaced or a good 1st transfer roller.
                      • 37533
                      You could also try cleaning the roller.
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        Would be good to see some more samples of other colour and some normal prints I've had something similar when a engineer fitted a 04 ptr in a 03
                        Regards Mark
                        • MIGUELMARCHENA
                          • Feb 2018
                          • 195
                          In the ricoh this problem has not happened to me, but in the panasonic and Toshiba yes.the problem was in the spent developer or had soil from the environment.as it was very expensive, it was removed, sneaked in with a half-evening, toner was added on a regular basis, and the problem was solved for a long time.Sometimes it was due to the roller in the development unit, it needed to be cleaned very well.
                          • tonerhead
                            • Sep 2009
                            • 582
                            Since there is no problem listing parts, the current number in parts finder is D0BQ6060. That is D,zero,B,Q,6,zero,6,zero. It probably updates the previous mentioned number. I also thought of switching the yellow with the black as was previously mentioned. Yellow is always nice and solid on these even with crappy drums and developers.
