Scanning ID or Large Document on Ricoh MP C2051
  • Nauman
    • 28
    [Misc] Scanning ID or Large Document on Ricoh MP C2051
    Hello ,
    I am new with Ricoh MP C2051, am trying to do scanning / copying of ID or document larger than A4 size or documents as in ID card size. I have tried searching alot on size customization etc and all youtubes tutorial coming up are of no help to me. Below is what am looking :
    1) Scanning / Copying an ID card on single A4 Page.
    2) Customise size for ID SCAN / Large Document setting .
    Looking forward for some help / dircection
    Thank You
  • GIUBOSS
    • 1436
    Re: Scanning ID or Large Document on Ricoh MP C2051
    Originally posted by Nauman
    Hello ,
    Thank You
    copy ID card, go to 1 Sided + Combine 1 Sided button and set the full size percentage. Place the document in the 'ps corner, flip the document after the first scan in the same position.
    • Nauman
      • 28
      I see option " 1 Sided + Combine 2 " or others nothing as you mentioned.
      • copier tech
        • 8172
        Hello ,
        Thank You
        You can set the ID copy function to display on the main screen this is what you need.
        Not the same model but you get the idea.
        ID Card Copy
