1018d not loading toner
  • ash_572
    • Oct 2008
    • 523
    lastweekk i put developer type 19 because the prints were too pale. tht sorted the problem out. this week customer says its not loading toner now. will this be sumfin to do with the dev i replaced or isit the toner bottle? any ideas?
  • kayjaig
    • 144
    try to run force toner, then check the toner entrance of DV unit to see any new toner trace were added there.
    • TonerMunkeh
      Professional Moron
      • 3865
      Also check that the mag roller drive gears aren't minced, favourite on these.
      Hit it.
      • fitsy.13
        senior tech
        • 64
        i have had a few problems with the bung not being pulled out the bottle far enough i removed the bung also had the previous bung from the last bottle in the hopper to
        • E Winter
          check if the toner motor/hopper/dev drive is working correctly
          • ash_572
            • Oct 2008
            • 523
            how can u check if the drives and motors are working correctly? output?
            • E Winter
              yes - the output check is a good start
              • copygirl
                • 75
                Hey Ash. I bet it's just the tonner hopper. It'll get to where it won't feed the toner thru. Mylars get worn out. Just replace it, tone it up and I bet it works.
                Ginger
                • ash_572
                  • Oct 2008
                  • 523
                  the hopper is actually droppin toner into the pcu. cuz the hole is full of toner.
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    If the hole's full of toner that means either the PCU isn't being driven correctly, the TD sensor is faulty or the PCU shutter is faulty. Pinch a PCU from another machine and see if it works.
                    Hit it.
                    • Eric1968
                      • 2458
                      I put my money on the development drive gears. Looks like the toner is not properly fed in the developement unit. I would replace the 2 gears and add new developer.
                      • E Winter
                        In this case I'd seconded Eric's statement
                        • iMind
                          Vacuum Cleaning Expert
                          • Mar 2008
                          • 1116
                          It can be a simple thing, did you check if the front door slide actuator that works with the microswitch is not stuck, this switch tells the machine that the front door has been open, when changing the toner bottle.
                          • Jomama46
                            • 2900
                            If the dev is full of toner, probably the mixers arent turning. They are driven by the 2 gears on the mag roll. The developer tears those gears up. If the gears in the dev section (3) are torn up dont replace them, replace the whole section.
                            sigpic
                            A+; Network +; PDI+
                            • ash_572
                              • Oct 2008
                              • 523
                              its got nothing to do with the door switches thts for sure. i replaced the dev section unit second hand. problem solved. lets hope tht one doesnt come back in.
