Lanier 5622 lines on print and copies
  • neergish
    • 177
    I'm having trouble finding out whats causing white lines appearing from a .
    The example is a sky shot, but there are the same lines on prints as well. (The paper is being fed long edge first)
    The lines are appear during image forming, I have stopped a copy halfway into the fuser.
    I have swapped out the PCU without success, thinking there maybe a build up of something on the charge roller.
    I'm tempted to think it may be the laser unit but the machine isn't offering a SC code at all.
    I performed a sky shot reduction (A4 to A5) but I cant discern whether the lines have reduced or not.
    Could a faulty transfer unit cause this?
    Any Ideas?
    "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
  • Ricoh-ono
    • 338
    Based on your example I would definitely replace the transfer roller. It gets full of paper dust and causes this problem. It will leave black dots in white areas.
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
    • copytechman
      • Nov 2008
      • 929
      Been there, done that. Bad/worn out transfer roller! Replace it!
      Regards!
      A.
      • neergish
        • 177
        Thanks heaps, One new transfer unit = a happy customer.
