C3503 keeps adding magenta toner
  • tinfox
    • 317
    This customer is an hour and 45 minutes away, so I want to make sure I have everything I need. The cyan toner was out and the others low, so they replaced the magenta and yellow as well. The machine keeps trying to add magenta and he said it's getting everywhere?
    I have a working machine that I can take whatever I may need. I am going to take all the drums, extra toners and waste toner bottle.
    Is this something common on this series? I haven't run into this problem before. (On an x03)
  • FrohnB
    • Jul 2017
    • 1919
    Omertà
    • fshead
      • 2376
      Re: C3503 keeps adding magenta toner
      I would pull the ITB cleaning unit and vacuum out and clean the metal guide,sponge roller and interior where all comes in contact
      with pcdu/itb unit.
      Also check if they are using OEM or chinese toners..
      there is a lot of crap toner being sold.......
      • tinfox
        • 317
        My. God. So I drive all the way out there and its calling for cyan toner. The icon to the left is red, so... He only put magenta in cuz thats what color the icon was.
        • anothertech
          • 1769
          It would be great if the machine had different color lights to indicate the color toner it needed. The red light was on, maybe he should have put in red toner.
          • tinfox
            • 317
            Yeah, it's not like the screen isn't full color.
            • copier tech
              • 8144
              If it keeps calling for toner most likely the dev gear has failed, so take a PCDU but once this happens it will take out the hopper of that colour.
              • sandmanmac
                • 3981
                It does if you enable "toner remaining Icon display" in SP mode.
                I do it on every (non SOP) machine that I've delivered
                • anothertech
                  • 1769
                  Do you know what SP that is?
                  • sandmanmac
                    • 3981
                    5061-001
                    Set to 1 to enable. Reboot machine
