MP5054SP odd delay
  • Gift
    • Mar 2011
    • 2459
    MP5054SP odd delay
    Hi Folks,
    I have a MP5054 wich suddenly started to "idle" for several seconds before starting copying/printing. Once the job is completed and you start another copy process directly afterwards, there is no more delay. We checked the enviromental data and didn't see a big issue there, humidity is 49% and temperture 16 degrees (checked via SP). Might seem a bit cold but I compared that to a used machine I have in my storage and that displays 13 degree and does not delay/idle. Anyone can give me a hint there?
  • copier tech
    • 8143
    Re: MP5054SP odd delay
    Originally posted by Gift
    Hi Folks,
    A few seconds delay is not an issue.
    Many factors come into play here.
    What are the sleep setting on?
    What firmware version is the machine on?
    It could even simply be adding toner.
    Even the PCDU being over PM life could cause a short delay.
    • Gift
      • Mar 2011
      • 2459
      Yeah I know but even my tech told me that this is an annoying behaviour. He already installed the latest firmware (package 7.0) and checked every non default-related SPs for odd values. Sleep setting is 60 minutes and PM isn't overdue. I think the total counter is ~200k so the unit is running with it's first fuser, perhaps I should check the thermistors and sleeve units and go from there.
        • 37481
        On older models, that you describe is exactly what setting SP 1103-001 to 2 will cause when the temperature is too cold. Check to see if Ru=icoh has moved SP 1103 to factory settings. There are also some delay settings in SP 1116. They are "For design use. Do not change." items but still might be different on some machines.
        • copyaction
          • Oct 2007
          • 991
            • 37481
            When set to 2 it only applies when the fusing unit is still cold. The setting of 2 was added with either the 1027 or 2027 to correct false fusing errors in the morning during cold weather.
            • M94
              • Jul 2020
              • 158
              Yeah just my two cents but it just sounds like the machine is compensating for a fuser that is taking longer to heat than it used to for whatever reason. Not really something I would consider a concern I don't think but if you're worried about it I would probably start by replacing the fuser and\or getting your ambient temps up a bit.
              I'm not familiar with this brand but there are likely involved count\maintenance\fuser settings that will also need dealt with...
              • anothertech
                • 1768
                If it is fuser related, check the paper tray settings, could it be set for heavier paper? Another random thought, How's the voltage at the wall? And yes, clean the thermistors.
                • Gift
                  • Mar 2011
                  • 2459
                  Thanks for the factory SP hint - you can fiddle around with the tresholds @factory SP1111. Default value is 17 degrees and I know there was 16 degrees on our cuustomers site.
                  Funny thing is that the MP3054 I have does not idle-run at all even if I roll it outside @7 degrees celsius ....lol
                  Probably the MP5054 acts different because of it's higher PPM value.
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    It hasn't had the slower fusing sleeve installed in it has it?
                    Hit it.
                    • Gift
                      • Mar 2011
                      • 2459
                      Customer is happy now, my tech just changed the lower temp treshold @ from 17-> 15
