MPC4500 without fiery
  • Natsu
    • 9
    Hello,
    i just recovered an MPC4500, but the fiery (E5000) is dead. how to connect the copier live without going through the fiery?
  • davel
    • Oct 2011
    • 1079
    Re: MPC4500 without fiery
    Reverse the Fiery installation instructions, there is an SP setting.
      • 36868
      SP 5985-001 Return to default.
      • Natsu
        • 9
          be careful.. being an end-user you can brick the machine if you aren't careful
          • Natsu
            • 9
            J ai toujours imprimer avec le fiery sur cette machine mais il vient de mourir et j ai vraiment besoin d omprimer en direct sans le fiery. Mais impossible depuis le port usb de l imprimante.
              why post in french when all your other posts were in english ?
              • tsbservice
                Field tech
                • 7916
                And brocken French as my old school memory recalls.
                  • 36868
                  Google translate, Google Translate, was able to translate it. I can't understand why those for whom English is not their natural language don't use it more often. It takes very little time.
                    • 36868
                    • anothertech
                      • 1756
                      I think I can help with this, I might PM them in German and make them translate it.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3945
                        It's been a lot of years, but I once had this model machine (with a Fiery) where we needed to remove the Fiery and use the internal controller.
                        It was NOT as simple as it may seem. Since the machine always had the Fiery, I remember that we had to add memory, and probably some other hardware, just not sure what it was.
                          • 36868
                          Checking the installation guide in the service manual, the bottom of the 2 512MB dimm modules is removed when the fiery is installed so you will need 1 512MB DDR DIMM module. You might also need to remove the interface board for the fiery.
                          Added: If you use the RPCS print driver for Windows 7, you might not need the additional memory.
                          • copier tech
                            • 8104
                            Hello,
                            Here's the E5000 service manual, follow the installation but in reverse!
                            Color Controller E-5000 - Color Controller E-3000 Service Manual.pdf
                            • Natsu
                              • 9
                              Hello,
                              can you help me i recovered this copier the fiery no longer works i followed the advice of other user. i add ram and set sp 5985 mode to 1 but cannot connect copier live to computer by connecting it to usb port.
                              Can you tell me how to do it
                              Thanks for your help
