Chatter on color only
    • 16455
    #16
    Re: Chatter on color only
    I can tell that each of those specks is ONLY K of varying percentages, with no C, M, or Y. And it's in a pattern in the main-scan direction, like a laser writes.
    Brilliant.
      • 23010
      #17
      I have not used it but it appears that the red circle is the pointer for what you want the tool to examine. ColorPic then shows you the breakdown of the color(s) of the area selected.
      Correct. Actually it's your cursor/arrow that points to the pixel, but the the cursor isn't captured in a screen shot, so I add the circle to help with the explanation.
      Interestingly, somehow Colorpic pointer has become mis-aligned with the cursor, low and to the right by about 50mm. If I change the scaling to 100% the pointer aligns again.
        • 37560
        #18
        What it needs is a calibration utility similar to Ricoh's, and probably other makes, touch screen calibration where it presents a number of dots on the screen and you click on them.
          • 16455
          #19
          I love these threads that get really deep into a subject.
