IMC300 Bluetooth printing?
  • jshah
    • Aug 2013
    • 53
    IMC300 has built in bluetooth in SOP, I have a client who wants to use it to print from his laptop but it always pairs as music device, tried to add the printer by using "Add Printer wizard" but the printer not discovered. Is it even possible to print on IMC series over bluetooth?
  • Brianneoe
    • May 2015
    • 318
    Re: IMC300 Bluetooth printing?
    yes.. https://tscweb.custhelp.com/app/answers/detail/a_id/251874/p/6621/kw/bluetooth/p_li/cF91c2VyaWQ9YnJpYW5Abm9ydGhlYXN0ZXJub2ZmaWNlLmNvbS ZwX2VtYWlsLmFkZHI9YnJpYW5Abm9ydGhlYXN0ZXJub2ZmaWNl LmNvbSZwX3Bhc3N3ZD03MDAwMDI2NDA5JnBfbGlfcGFzc3dkPX IxYzBoMW50M2dyYXQxMG4mcF9yZWRpcmVjdD0xJnBfbGlfZXhw aXJ5PTE2MDc3NzQzNjE%3D
    • copier tech
      • 8142
      Why does he want to print via Bluetooth? this is a very unreliable method.
      Can he not simply print via IP?
        • 37460
        Nice link, if you have access Ricoh-USA service websites. If you are from another part of th e world it is totally useless.
        • anothertech
          • 1766
          the link is not even a useful if you have access to Ricoh, it just takes you to the TSRC home page.
          • jshah
            • Aug 2013
            • 53
            Printing via IP or USB is not applicable due to some limitations. They have been using printing over bluetooth on their old mpc2051 and need same set up on new imc300.
              • 37460
              Unless there is a Bluetooth option for the controller I believe that the SOP Bluetooth has a very limited range, like 5 meters or less. What about connecting to it with a USB cable?
              • copier tech
                • 8142
                Bluetooth printing on an MPC 2051 you sure?
                If they don't have the copier on a network I would simply run a LAN cable to the machine or better still create a simple little network with no net access if they're concerned about security.
                • Brianneoe
                  • May 2015
                  • 318
                  mea culpa
                  Sorry for the bad link..Major DUH on my part. Bluetooth printing does work but as stated above it does have limited range.
                  • anothertech
                    • 1766
                    Bluetooth.pdf
                    Did you load the driver like it says on page 15 of this doc?
                      • 16374
                      Soon as I read the title of this thread I thought: "oh great, something else to learn."
                      I've never seen bluetooth printing and I won't be heartbroken if I never do.
                      I did read that there are bluetooth extenders just like there are wifi extenders.
                      Bluetooth technology offers a convenient and fast way of connecting smart-driven devices. ... Fortunately, it's easy to overcome this range limitation with the best Bluetooth extender. These plug-and-use devices normally extend your Bluetooth Wireless range up to 100 feet indoors and 300 feet outdoors
                        • 37460
                        Optional hardware item. Uses the same controller slot that can also be used for the the IEEE 1284 parallel interface and the wireless interface. From the installation instructions in the service manual it looks like might be a PCMCIA Bluetooth card and proprietary adapter.
                        • jshah
                          • Aug 2013
                          • 53
                          Thanks everybody for your suggestion. It did work, connected the printer and laptop/PC to the same (WiFi) network, chose Bluetooth port while adding the printer and it showed up in the list.
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            Airprint can also be used with windows... even a c2800 will print.
                            Easy to set up.
                            • copier tech
                              • 8142
                              Out of interest when the copier & laptop are on the same wifi network why do you want Bluetooth printing!? why not simply set up regular PCL wifi printing via IP?
