use many toner
  • copylinks18
    • 2
    [Dead] use many toner
    hello..i am new here .want to ask wat problem cause like this..
  • 8T2
    • Aug 2015
    • 257
    Re: use many toner
    More info pls? Total Counter? PM counters?
    I'd bet the developer is over yield and possibly drum. Or non genuine developer and drum
    Sent from my WAS-LX1 using Tapatalk
    • copylinks18
      • 2
      Re: use many toner
      ricoh 7502 ..
      1 kg toner meter 10000
        • 37553
        Re: use many toner
        Originally posted by copylinks18
        ricoh 7502 ..
        But who is the toner from. That looks a little low for a MP 7502 considering it is a pre production model that was first released over 8 years ago.
        Normally with toner being dumped there where at the right end of the duplex it is coming from the toner bottle tray or the recycle tube.
        • sandmanmac
          • 3983
          Re: use many toner
          ricoh 7502 ..
          Me thinks there are a few Zeros missing on that total counter........Or it's been reset.
          There's no way that's original COUNT or it would still be on it's very first bottle!
            • 16446
            Re: use many toner
            That machine looks like it's been driven hard and put up wet.
            • allan
              RTFM!!
              • 5462
              Re: use many toner
              Really no model to start with. Are you a qualified technician?
              And guess its not dead?
              Whatever
                • 23010
                Re: use many toner
                I've had customers do this: They open the front door and point to a circle of toner on the door like it's evidence of a major malfunction. After 8 years I would be very surprised if there wasn't some toner spilled, and certainly more than 10,000 copies.
                You do know that this machine consumes large amounts of toner, and not all of it stays in the bottle? A couple of wipes with a dust cloth can solve this pretty quickly.
                I assume that there's another reason that you're asking. Try again. =^..^=
                • skynetto
                  • Sep 2012
                  • 257
                  Re: use many toner
                  That pig can produce 10.000 pages x day if not more. There is no way its is so dirty with only 10k pages. Lot of maintenace to do it seems.
                  I've older models still going on with 5M+ pages way more cleaner than this.
                    • 37553
                    Re: use many toner
                    I had high schools where 5M was the replacement mark. Going all the way back to the Aficio 700. Still clean and making good copies at that count when traded in.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Re: use many toner
                      Let's start with best machine ever made by ricoh and still going.
                      Give good clean replace developer and filters, dev seals etc and check Dev unit for leaks setup correctly and only use oem also check toner recycle system and check seal in toner hopper.
                      Regards Mark
                      • KeviM
                        • Oct 2019
                        • 327
                        Re: use many toner
                        These are normally good machines. I've had customers in universities run their machines 24 hours a day during exam times.
                        What I've noticed regarding toner is that when the machine is fully serviced and the drum, developer and filters are new you will get roughly 50000-55000 copies / prints @ 5-7% coverage.
                        When your drum and developer starts going beyond it's PM cycle the machine will still work but you will start getting less copy yield per toner. Generally the toner yield on those machines used to drop to 40000-45000 and will still drop further if the PM isn't done.
                        Like the other guys said (and also the mostly likely fault) is the machine requires a major clean up and service. Also change maintenance parts including drum , developer and filters. Remove toner hopper, strip and clean and reassemble.
                        Also, 1 more thing , all guys say this and I'll say it with them again, use OEM parts.
                          • 37553
                          Re: use many toner
                          I always say use Genuine Ricoh. OEM does not guarantee the testing, quality and consistency of Genuine.
                          • KeviM
                            • Oct 2019
                            • 327
                            Re: use many toner
                            I always thought OEM was Genuine Ricoh. Thanks for clarification. And yes I do actually mean Genuine Ricoh parts.
                            Please always use Genuine Ricoh parts. Thank you Slimslob
                              • 37553
                              Re: use many toner
                              The term OEM actually means made to the Original Equipment Manufacturer's published specification. Is does not mean made BY the Original Equipment Manufacturer. Take toner and developer for example. They only need to contain the same basic ingredients in the same ratios, plus or minus legally allowed variances. It does not mean the same particle size, consistent shape or testing and inspections.
