MP C3002 Photocondutor units not set correctly
  • ervinr312
    • Feb 2015
    • 4
    [Error Code] MP C3002 Photocondutor units not set correctly
    Hi all,
    I have a MP C3002 that worked fine and slowly colours went out.Then I realize somone took the black pump and unplug other pump sockets and broke magenta pump wires.I; put a old pump from 3300 to black and repaired magenta wires,installed new toners and opened machine.Now it always says set photoconductor units properly,mostly for black and sometimes for all.Black unit is got broken for sure I tested it on other machine and got same error.
    I suspect repaired pump wires,if they have +/- side but not sure about that.I also checked and replaced developer sockets,there is no problem on that.Other posible reason I gues is toner chips cause this but not sure.
    I stucked any one have experience with this situation ?
    • 37550
    Re: MP C3002 Photocondutor units not set correctly
    One major possibility considering that someone has been jacking around with the machine is that the connector between the PCU and the DVU is unplugged.
    • GIUBOSS
      • 1437
      Originally posted by ervinr312
      Hi all,
      Classic situation where someone puts their hands where they shouldn't ... replace the tampered toner pumps with new ones, check if all the toners are original, for the pcdu they may not be inserted correctly.
      • sandmanmac
        • 3983
        Hi all,
        I would suggest getting in contact with "someone" and having a "conversation" with them......
        You asked "Anyone have this experience"?
        I highly doubt that ANYONE has had "someone" just show up and start screwing with a perfectly operational machine and then apparently just disappears into the night??
        I think you're alone on that one!....
        I'm curious why you ONLY checked the black unit in another working machine and not all the units ????
        But obviously, if you already know that the black unit has a problem, that's a fine starting place, but I doubt it's the only issue
        • anothertech
          • 1771
          LoL, this just made me laugh.
          • sandmanmac
            • 3983
            Happy to oblige
            • Gift
              • Mar 2011
              • 2459
              You guys are mean, I'm still learning that, too
              That's Not My Job!
              This is a story about four people named Everybody, Somebody, Anybody and Nobody.
              There was an important job to be done and Everybody was sure that Somebody would do it. Anybody could have done it, but Nobody did it. Somebody got angry about that, because it was Everybody's job. Everybody thought Anybody could do it, but Nobody realized that Everybody wouldn't do it.
              It ended up that Everybody blamed Somebody when Nobody did what Anybody could have done.
              back to topic:
              Usually re-seating the units should do the trick but since the issue is re-produceable in another machine it must be the black drum- or dev unit. "Somebody" might check the connector that goes from drum unit to the dev unit and the other connector to the TD sensor pcb and that pcb itself.
                • 37550
                Am I getting an echo?
                • Gift
                  • Mar 2011
                  • 2459
                  Oohps you already posted that, must have overread it while digging in to that anybody, somebody, whateverbody story
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Hi all,
                    The pumps from a mpc3300 are not the same. This problem is usually caused by cheap toner cartridges with rubbish chips
                    Regards Mark
                    • mikadonovan
                      • May 2008
                      • 2931
                      A little off track of the thread, but when I was much younger I responded to a call on one of my hospital machines, and noticed the Sharp tech had been working on one of his machines in the same area. After reviewing the state of his disassembly, I decided he did not have nearly enough screws in his pile, so I helped him out by adding a handful of my own from my screw stash. Lol, I still chuckle over that. I really would have liked to been there when he (or she) experienced the WTF moment and wondered what they had forgotten to put back together
                      NEVER ASSUME ANYTHING
                      • sandmanmac
                        • 3983
                        Hahaha..... That's awesome Mika!
                        Hopefully there were a couple springs and clips in your stash as well
                        That WTF moment would be priceless!
