mpc3003 "problems with SCC cable"
  • luca72
    • Oct 2017
    • 1781
    #16
    Re: mpc3003 "problems with SCC cable"
    Originally posted by Mark Bbb
    Hoi,
    Never had this issue before.
    We delivered this machine Monday and this morning (Wednesday) customer calls for this error.
    He says he had moved the machine (about 2 meters) and used another LAN cable (shorter) and that it worked well (after he moved it) untill all of a sudden... (must we believe this?)
    This we already tried:
    Machine had also USB cable plugged in, unplugged it. Using another LAN cable. Machine off and back on. Deleted the print que. Removing and re-installing the driver.
    We do have a good WIM connection (even log in). Only the yellow LED light on the LAN cable interface is on. The print stays in the que but scanning is no problem.
    Thank you for your help.
    I would try the first thing, I go there, with a laptop and a cross cable, then, try to replace the hdd, sometimes they make really weird jokes (especially when the mc is moved / transported), then I would try sp 5- 801- (nic, printer eccept engines)
    regards
    "I'll be back"
    • lizasolovy@gmail.com
      • Apr 2023
      • 1
      #17
      Guys! I'm looking for a reliable POE cable tester that guarantees accurate results the first time? Don't want to waste time on low quality hardware if the website offers high quality testers to help you get the job done right?
      • paulssamoss
        • Apr 2023
        • 1
        #18
        Why settle for subpar equipment when you're testing your POE cables? Our website offers top-quality POE cable tester that will ensure you get the job done right the first time. Don't waste your time with unreliable testers, trust our products for the best results.
          • 37513
          #19
          Take your spam and shove it your asses.
