Aficio MP 501, How good is it?
  • MIGUELMARCHENA
    • Feb 2018
    • 192
    have a good day all of you
    I want to ask a question
    How did you like the MP 501?
    I appreciate your opinion because we are about to say if we buy these teams.
    thank you very much
  • CopyBats
    • Aug 2011
    • 145
    Re: Aficio MP 501, How good is it?
    thank you very much
    Ricoh moved on to a new LED system for writing on the drums. These machines can do few 100ks on them but I have experienced early drum failures couple of times. Especially in environments where print density is darker......
    SP5210 were a different beast...
    If it works, don't touch it.
    • anothertech
      • 1766
      So to follow up on this, what do you mean by "SP5210 were a different beast", is that a good thing or a bad thing? The LED system seems to be a good thing.
      • CopyBats
        • Aug 2011
        • 145
        SP5210 were a workhorse. I had several at 500k + and 1-2 that reached a million.
        LED use power less but If you don't have access to good prices on the drum units, they're not worth it
        • skinnyb
          • Jul 2008
          • 291
          Originally posted by terramobil
          It's not a real Ricoh machine, it's a Kyocera with a Ricoh labels, operation panel and SP Modes. You can use most Kyo spare parts, maintenance kits etc. In Germany, the Kyo parts are much cheaper compared to Ricoh parts.
          Truth. Not my favorite. The consumables are very difficult to change (Fuser, pcu, dev unit) and they do not last anywhere near their rated life. And the controller board requires a contortionist to remove when it fails as it's a Ricoh part shoe horned into the Kyocera frame.
          Sent from my LM-V405 using Tapatalk
          • copier tech
            • 8139
            This is good to know.
            What Kyo model consumables do you use on this Ricoh MP 501? and are they a stright swap or do they need a mod etc?
              • 37449
              Originally posted by chrisjordan
              Indoor gardening has become increasingly popular in recent years, and for good reason. It allows you to grow your own plants, fruits, and vegetables in the comfort of your own home. With the right tools and equipment, you can create a perfect growing environment that will produce healthy and robust plants. Growtentmate makes this process easier by providing you with all the necessary products and information to get started. Best dehumidifier for grow tent 2023 And Buyers Guide
              Take your damned illegal advertisement messages and shove them up where the sun don.t shine.
              • Ricopier
                • May 2023
                • 1
                is a good machine, i have 30 MP501 and give me good resault.
                • MIGUELMARCHENA
                  • Feb 2018
                  • 192
                  yes, i could check it.
                  these machines are a rest
                  greetings.
                  • Klydon
                    • Mar 2009
                    • 243
                    Late to the party on this one.
                    In short, I am not a fan. You can read on if you want to see specifics.
                    Fusers do not reach yield at all. Not even close in most cases.
                    PCU's are not a lot better.
                    Machine overall is noisy and a lot of times, that noise is either from the PCU or the fuser. The good news is the machine has a "silent mode" that drops the speed and the noise. Over half my machines are in silent mode.
                    Pray you never have to change a right rail because the paper won't lift. It isn't fun at all.
