mpc3004 ITB belt replacement, warning!
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    This info is not in the serv manual and very important:
    When you just have slided the new belt over the ITB frame, you must look for two alignment guides (black and round) on the iron roller on the part that hinges.
    The alignement guide at the rear is movable, you must move it upwards (and hold it that way!) at the same time that you align the belt between them. Hold it like that and then you close the hinge to put pressure on the belt (tiden it up) but be sure to keep the alignement guide upwards!!!!
    If you fail, the belt will get (easily) damaged, because the belt is larger than the alignment guides.
    When you are capable, use your 3 arms!
  • GIUBOSS
    • 1435
    Re: mpc3004 ITB belt replacement, warning!
    suggestions are always appreciated, thanks
    • copier tech
      • 8144
      Originally posted by Mark Bbb
      Hoi,
      The easiest way to fit the belt is tip the ITB unit up on the front side, then slide a log screwdriver through the handle this supports the unit while you work on it, stops in falling down. Now you are free to use both hands.
