Ricoh MPC 3004 with CMYK on top of page
  • Alex1
    • Oct 2012
    • 285
    Hi all,
    I'm going out to see a Ricoh MPC 3004 which is printing CMYK across the top of the page every now and then. This job is a far drive for me, I was wondering if anyone has come across this problem before? Please see photo attached.
    Re: Ricoh MPC 3004 with CMYK on top of page
    Originally posted by Alex1
    Hi all,
    the belt cleaner isn't removing those test marks
    be nice to see examples in PDF format yours are a little too small.
    • copier tech
      • 8187
      Hi all,
      Classic issue, you have the MUSIC patterns on the prints.
      Update the firmware & clean the patch sensors.
      • anothertech
        • 1771
        Check the side to side registration of the paper. Replace the ITB cleaning unit.
        • Gift
          • Mar 2011
          • 2459
          Usually there's just dust or fluffy stuff collectet in the transfer cleaning unit - cleaning should do the trick or in case it doesn't or the meter redings are very high you might consider to nstall a new one. I'd also put a new itb unit in the car just in case the installed one has a little damage on the surface, too.
          • Debs1964
            • Oct 2010
            • 1693
            +1 on this suggestion
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • Alex1
              • Oct 2012
              • 285
              This done the trick. Thank you all for your help.
              • Alex1
                • Oct 2012
                • 285
                The machine already has the latest firmware however I did clean the patch sensor. Thank you for your reply.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Hi all,
                  Quite common itb cleaning assy it's common if a engineer replaced they forget to take the 2 side securing brackets of the old assy.
                  Regards Mark
