DSM 721d won't fax to most numbers
  • yakyitz
    • 244
    It'll basically send to only 1 location. When sending anywhere else just hangs up and most of the time won't even give an error message on the screen. Most probably I'm missing something becuse I can't find where to printout journal with failed calls with error codes. Also I tried lowering the tx speed, all it accomplished was could send to 1 other location but not the original location.
  • TonerMunkeh
    Professional Moron
    • 3865
    What's a DSM 7214?
    Hit it.
    • yakyitz
      • 244
      DSM 721d
      Sorry I mistyped model number.
      • Jomama46
        • 2900
        To print a journal, press Job information>Print Journal>Print.
        To test I would use the On Hook dial key to get a dial tone, then dial the number and wait for a fax to answer, if it doesnt you know where the problem is. If a fax answers press the Start key and see if it goes thru. Do this for all the failed calls to find out whats happening.
        If all the failed calls are LD then maybe it is the carrier.
        Try those same failed calls from your office and trianglate the problem. This may tell you if the problem is in the local CO or the local line.
        Hook up a analog hand set and see if you can detect any noise. ANY noise acn disrupt a fax signal.
        sigpic
        A+; Network +; PDI+
        • TonerMunkeh
          Professional Moron
          • 3865
          You never mentioned whther the machine is okay receiving faxes from the numbers it can't dial, have you tried it?
          Hit it.
          • yakyitz
            • 244
            It's been awhile since I've been at this machine. Did try dialing on hook which if I remember correctly gave me mixed results. I'll post an update once I get more details. Thanks.
            • Fearless V K
              • 620
              Try turning off ECM, if that doesn't work try a memory all clear on the fax module.
              Don't take that toner with me!
              • yakyitz
                • 244
                Ok guys Thanks and here's the deal. Haven't gone back yet. But, spoke with the cust and they are using another machine for outgoing using the same line without a prob. They are getting all their rx on the 721d. I'll try turning off ECM and doing an all memory clear and see what happens
                • yakyitz
                  • 244
                  Turning off ECM did the trick. Thanks again
