I get a message ' loading toner' repeatedly - this resulted in the development units/ PCU's below cyan covered in cyan toner. Help! any ideas or leads gratefully received.
I've had this a few times. By the look of things it sounds as if your cyan toner supply pump is blocked or one of the tubes leading to it is blocked. If you are a tech it can be a big job and if you haven't done it before I would suggest following the manual.
Could this be one of those cases where someone before him has been experimenting with different units in different machines?
Just thinking out loud.
Normally, I would guess toner pump. But he says toner is spilling out around the edges (tells me pump is working). Might be pump. Might be misfit. Might be something else.
If I am right (hopefully not), this is the downfall of experimenting without good documentation that every tech in your organization knows to look out for.
Hi Guys, I replaced the cyan dev unit, cleaned up the spill, problem solved. You guys are amazing! By the time I came back from my office there were 5 advice messages. More stength to you elbows. Thank you
I will certainly tell my friends about Copytechnet.
