mp c2011sp error sc547-02
  • senakainoki
    • Nov 2019
    • 25
    [Error Code] mp c2011sp error sc547-02
    hi,
    I have face problem MP C2011SP SC547-02. As per the technical bulletin i have check connection in between PSU (AC) and CONTROLLER Board.
    Still the same. Please advise me anybody face same issue..... Latest firmware has been updated.
    senaka
  • francisco
    • Nov 2009
    • 168
    Re: mp c2011sp error sc547-02
    Originally posted by senakainoki
    hi,
    senaka
    fuser problem
    you have to check fusing section, if damage replace,then you must reset the code,like says in manual.
      • 37515
      SC547-02 is a Zero cross error (relay contact fault). Check fuses on PSU. Replace the PSU.
      • luca72
        • Oct 2017
        • 1781
        hi,
        senaka
        check well also the various door switch , that can generate "zero cross signal"
        "I'll be back"
