mpc3003 firmware upgrade E57 & E53 & 'invalid data' errors.
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: mpc3003 firmware upgrade E57 & E53 & 'invalid data' errors.
    I have put the data straight in the folder 'romdata' -> 'invalid data E24'.
    BUT
    I have checked the diagnostic page for newest firmware, and all the firmware is up to date -> i think that this error (E24) occurs because of that.
    When one item (f.i. engine) would have been older than the update, errors won't occur and the update would be executable.
      • 8149
      BUT
      If you have the correct files in the romdata folder then your SD card is faulty.
      You can update 10 year old factory firmware to the latest without any issues.
      However you need to update the romdata modules before you update the package.
      • satins
        • Feb 2021
        • 89
        BUT
        Try one of the old postscript or printer/scanner or any other java card (from older models) which does not has any relative information related to Ricoh Mp C3003 or related series.
        Use the SD card, format it with windows utility ( right click and click format, usually takes 20 seconds).
        Copy the romdata with .fwu files and follow the process.
        In case the code pops up again, look toward the Printer controller for resolution.
        worth a try!
        • satins
          • Feb 2021
          • 89
          #19
          worth a try!
          I forgot.
          The older SDCARD may turn useless.Sorry for missing that piece.
            • 37502
            #20
            BUT
            According to the service manual, E24 would be Card access error 1. Reinsert the SD card 2. Replace the SD card.
            • Gift
              • Mar 2011
              • 2459
              #21
              BUT
              If the FW is up to date I'd say don't bother anymore Might be just a bug, you'll probably find another MPC3003 to check that card + files.
              • luca72
                • Oct 2017
                • 1780
                #22
                The Panasonic SD Card Format Utility is no longer available from Panasonic. Their website will redirect you SDcard.org. As I am retired and no longer have access to TSRC I don't know if Ricoh has a link of not. There are other utilities that will work. What I like is Mini Tools Partition Wizard. It will also allow you to partition the drive to a smaller size before formatting. If you have a machine that will only work with a 2GB or smaller SD card and all you have is a 16GB, no problem. It is free for personal use.
                i've been using mini tools for years too, crazy cool, better than partition magic
                "I'll be back"
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  #23
                  Slim, i know, but
                  1. this SD card is new for a few months and never have any problems only with c3003
                  2. because the firmware was already up to date, i think the c3003 creates this errors. Let's just say it's software is programmed with a wrong message when there are no files to be updated...
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    #24
                    Some machines of that age don't like SDHC cards. All the cards I buy are non-HC.
                    Hit it.
                      • 8149
                      #25
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        #26
