ricoh mpc4000
  • stevekiv
    • Feb 2021
    • 2
    ricoh mpc4000
    a toner of cyan is not recognized when i replaced it
  • copier tech
    • 8144
    Re: ricoh mpc4000
    Most likely your cyan toner pump has failed or the pipe is blocked.
    You can swap the pump with another colour as a test.
      • 37491
      Re: ricoh mpc4000
      Bad RFID board.
      • luca72
        • Oct 2017
        • 1778
        Re: ricoh mpc4000
        if it doesn't work one is the bottle, if no cyano bottle works, it could be the pump, take apart the pcdu and look into the hole where the toner falls inside, if it is empty it is the pump, if it is full to burst, it is broken there axis of some agitator in the developer unit, check also the rear plastic gear
        "I'll be back"
