MPC3004. display in copier mode . .
  • GeorgeBest
    • Jul 2009
    • 525
    Got this MPC3004 returned from customer.
    Now, when I trie to copy or scan i get the message in display. "To use the following function(s). set key card.
    Can I disable this "key card " function? and so how do `I do that?
    looked in the WIM, but I can't see where ho disable this key card . . .
    anyone?
    Thanks in advance
    gr George
  • Asaadahmed003
    • Jun 2019
    • 24
    User tools / system settings / administrator tools / key counter management / set all to OFF
      • 8131
      Re: MPC3004. display in copier mode . .
      Originally posted by GeorgeBest
      anyone?
      Thanks in advance
      gr George
      Sounds like the machine had a software solution previously.
      There’s an SP mode to turn this off check the service manual but I think it is SP5-113
      • ridgemill
        • Sep 2017
        • 184
        Go to User Tools > System Settings > Administrator Tools > User Authentication Management, and set it to OFF. Also, go to Enhanced External Charge Unit Management, and make sure no options are highlighted.
        You may also need to turn off Administrator Authentication Management.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          +1
          Regards Mark
          • luca72
            • Oct 2017
            • 1750
            anyone?
            Thanks in advance
            gr George
            as copier tech says, after you have unlocked it, please remove any software, especially if you do not use it, disable the java environment (sp5-730> 0) ... and then fasten your seat belts! .. LOL
            "I'll be back"
            • tsbservice
              Field tech
              • 7986
              What a nice ending touch
              Saluti!
