Mp 2001 Solid Black Copies
  • spaceman99
    • Jul 2009
    • 174
    [Misc] Mp 2001 Solid Black Copies
    Hello
    Can you help please ?
    Have a Ricoh mp2001 . Doing solid black copies. Changed HVT Power pack and PCU . All connection on rear of PCU look good. Was thing BICU ? Any ideas welcome. Thank you in advance.
    Re: Mp 2001 Solid Black Copies
    Originally posted by spaceman99
    Hello
    what are the PM count on parts?
    condition on drums/dev units?
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Hello
      Did you rebuild pcu or replace
      Regards Mark
      • tsbservice
        Field tech
        • 7937
        Hello
        How about printouts?
          • 8119
          Hello
          Try a new PCDU.
            • 37047
            Solid black indicates no charge on the drum. Since you say you have replaced the PCU and High Voltage Power Supply that leaves the contact spring at the back of where the PCU slides into the machine. It is not lining up with the opening in the back plate of the PCU that you can see the charge roller contact plate through.
            • luca72
              • Oct 2017
              • 1710
              Hello
              hi, try to check inside the white or black plastic support of the charge roller, there is a contact with a tungsten ball, sometimes it has happened that it comes off
              • Debs1964
                • Oct 2010
                • 1687
                ^ this
                There are 10 types of people in this world, those who understand binary maths and those who don't
                • FrohnB
                  • Jul 2017
                  • 1919
                  Are you trying to copy; Money, death certificate, or checks? Those will come out solid black.
                  Otherwise, slim and others have the right idea with the contact.
                  Omertà
                  • spaceman99
                    • Jul 2009
                    • 174
                    Hello
                    RESOLVED. Contact on rear of drum cracked behind gearbox. Causing no contact to charge roller. Hard to see at first. Replaced contact and all ok. Thank you all for your help and support.
                    • FrohnB
                      • Jul 2017
                      • 1919
                      Awesome! Thanks for the follow-up!
                      Omertà
