Stained image on ricoh 2503
  • tuliolin
    • Mar 2021
    • 1
    Good morning for everyone, i'am having some troubles with a ricoh mp2503.
    20210315114537955.pdf20210315114537955.pdf
    how can you see in the attachment the scanned image or copy is getting stained on all jobs.
    i aleardy changed all the boards (scan, main, energy and the scanner base, but nothing has changed.
    • 37556
    Re: Stained image on ricoh 2503
    [ATTACH]48597[/ATTACH][ATTACH]48597[/ATTACH]
    By the term "all jobs" do you mean copying, printing and internal print jobs like the counter sheet or is it just when copying?
    • Debs1964
      • Oct 2010
      • 1693
      That looks like you have trapezoidal copies, scanner has been leant on so is twisted out of alignment, try lifting the front left of the scanner
      There are 10 types of people in this world, those who understand binary maths and those who don't
      • GIUBOSS
        • 1437
        Singular defect. Like Slimslob, if you want concrete help you have to explain in detail if the fault came suddenly or after a replacement, any clues would be appreciated, even if it makes me think about the first approach to the defective transfer unit.
        • luca72
          • Oct 2017
          • 1791
          in case you do it only with scans and copies, it seems that there is grease (grease, oil, other) finished on a portion of the mirrors, you have by chance put too liquid lubricant on the guides to eliminate the classic noise of the carriage guide on that machine?
          "I'll be back"
          • Mark Bbb
            • Jun 2012
            • 1662
            What are the counters? Machine standing in normal conditions?
            Persuming the paper is A4 LEF or portrait ...
            I would remove everything and put it back in.
            Still the same?
            Bad laser or the IPU.
